Jump to content
jessenator
4400/200 - dirty to clean
Recommended Posts
Weird. The original discs are definitely 7.5.3. MT could be wrong I guess. Maybe I'm misremembering too. Was 7.5.3 called update 2 or something weird? The nomenclature for 7.5 and its variants seemed scattered, but then again it was the Spindler era...
Worked just fine to restore system from disc and then a quick update to 7.6.1 and I'm golden! Not even a system enabler in the system folder. Runs smooth.
Just need to download a UDF extension and the Rage128 drivers. Although I've got good native support as it is. It's nice and light. Uses about 1/3 of the RAM 9.1 did.
Share this post
Link to post
Share on other sites
2 hours ago, EvilCapitalist said:
Somewhat amusing that the Sonnet box art clearly depicts a 4400, when I'm betting the majority of folks buying these were picking them up for 64/6500 towers and the TAM.
Exactly… I've never seen numbers, but I'm guessing those two eclipsed the 4400 sales, or at the very least were kept around longer… I had never even heard of the 4400/7220 until I joined this forum.
In all truthfulness, I'm preferring this upgraded 4400 over the G3 MT I got, but it might just be the optimization going on with 7.6.1—I haven't found a bootable Mac OS 8.0/8.1 image out there— I tried one from Macintosh Garden, labeled as the Beige G3 restore disc, and tried to match what little they had regarding ROM revision compatibility (my MT is rev. 3), but no dice—however, I have noticed the OE CD-ROM is spotty in its ability to read burned discs. Might just be dirty… The Plextor CD-R is just fine, and I finally got a Toast 4 upgrade so it recognizes it, so I can put it through its paces.
I'll probably track down an 8.0 retail image somehow. (maybe it's on Cory's repository?) 8.5 retail booted right up, but it feels weird to me for some reason I can't pin down. I want to do a full suite of my own "tests" on the optimal OS for each, so I'm guessing it's either 8.0 or 8.1 for the Gossamer MTs/DTs, but correct me. I've read 8.6 it its time was "not all it's advertised to be" but that came from a questionable internet source.
Once my loopback cable arrives I'm going to test the PC card in the 4400 first. The guy I got it from tested it and it registers as a video card, but with no drivers, etc., that's probably fairly accurate.
Edited by jessenator
Share this post
Link to post
So, meh news.
The 64MB EDOs I got were single-banked/ranked, and for some reason the computer only recognizes half of it :rolleyes:so go figure. Well, if anyone needs 3.3v RAM for their IBM build or whatever, I'll give them a good deal. My PC card loopback cable came though
Share this post
Link to post
Would these work in my PowerBase 200?
I'm not sure if it's the RAM or the logic board, because there's this weird problem I hadn't noticed before where it sees a 64 MB DIMM as 16 MB (with 8 MB as logic board RAM?) and the stock 32 MB as 8 MB? 32+64+64 should equal the maximum of 160 MB, but I only get 96?
Anyone know what the problem might be, and if a reasonable solution exists? I'd replace the logic board with the other one if ADB and PS/2 weren't both dead (they probably share the same, apparently defective circuit?)
Thank you?
c
Share this post
Link to post
I'd totally send them your way, but I looked on Mac gurus and those need 5v 2k refresh DIMMs apparently, though. Bummer.
Share this post
Link to post
I think I'd like to try 8.1 (especially now I have a 3-PCI riser and can use a non-COMMII card with other things) just for kicks, but I'm liking the performance I'm getting with System 7.6.1
Share this post
Link to post
22 minutes ago, 68kMacx86 said:
So is an Apple CD-ROM required?  I'm having a similar issue with mine.
I think any ATAPI standard CD-ROM should work. I never got around to just testing other ATAPI CD-ROM drives I have sitting around to see if they read—I just shortcut my way with an OEM, yet faster drive that I knew would work.
My issue was that it had no OS to begin with, and the floppy was bad, so I had to get it to boot, and finding the correct disk image proved a challenge. The only two (of many tested) that would native boot was the 4400-specific restore (or the small-business variant), and the retail Mac OS 9.2 disc. There may be others, but out of the ones I tested, those were it. Most surprisingly, the retail 7.6/7.6.1 image I had didn't boot either. I want to say I got it to install the OS on a CF card I had, but no booting.
Share this post
Link to post
7 minutes ago, 68kMacx86 said:
My 4400 rarely recognizes cds. It sees the drive on the bus but doesn’t mount the discs. Usually. Could be I don’t have a PRAM battery installed
Interesting. The 4400 shouldn't technically boot without a working PRAM battery. The Tanzania and a couple other Apple/AIM architectures are designed that way IIRC. The Performa 6xxx I think were that way.
You could try carefully cleaning out the CD-ROM to see if you have some increased readability that way. If a cleaning doesn't work, it might be worth getting a new drive. Others might have differing opinions.
Share this post
Link to post
I had to adjust the potentiometer on the laser of the Apple drive. It reads discs now. But sure enough the 4400 only sees Apple ide drives. Maybe could it be that my other drives were IDE DVD burners?
Share this post
Link to post
Could be. I did try my ATA/IDE SuperDrive spare from a Mac Pro 1,1 but since I didn't discover it was the image not booting till after I already got a 24x ATAPI drive, I didn't bother to test it further.
It could be a good excuse to fire up my 4400 again, I guess…
Share this post
Link to post
Heh, it's more time for me than anything. I'm super late to the game (literally) and am really deep into Skyrim, so it's eating up whatever spare time I have, which isn't much.
Share this post
Link to post
AAH, I don't get into many modern games except for Watch Dogs, I like the open world driving based games where you can do as you please.  The only reason my desktop has a good video card is to run Mac OS.  Otherwise it would just be onboard video.
Share this post
Link to post
Time to dust off these cobwebs…
Well, I think I'm going to mod the back I/O panel to accommodate my Starmax board. And thankfully I've remembered the classic maxim: "measure twice; cut once" or "drill" in my case.
I went through with my micrometer to measure the holes in the metal chassis itself, then measure the gaps, thinking the gaps would be universal down to the extra 2 mini-DIN ports:
Then I thought, hey, I should actually measure the board I'm going to put in. Lo and behold, there's some variance :)
So I'll have to redraw my marks tonight, but I'm glad I caught myself. Bought a 17/32" (13.5mm) HSS bit, so it should fall within spec by .5mm for the holes. I'll also widen the video port hole as well. I'd rather it stick out slightly than get caught.
I guess I should point out that the Starmax board, though mostly identical to the 4400 board, does not fit with the current mounting solution: the pegs don't align, most reasonably  because the additional PS/2 ports push against both the chassis and the I/O shield just enough. I think the HD-15 output also presses against the video cutout. The solder points are further forward from the DB-15 contacts, so there might have been a small margin of error there as well.
I also will need to do some troubleshooting on the Starmax board, starting with a re-install of the Sonnet drivers (probably an older version, as referenced here. I'm getting a boot crash as it tries to load the Sonnet extension, and although the instructions may be behind the last version of the drivers Sonnet wrote, it might not hurt to try just an older version first. I also thought about installing MacOS 9.
On my 4400, I was able to get the G3 Sonnet driver working on 7.6.1 as well, so once compgeke uploads his newly-acquired Starmax 7.6.1 CD image, I'll download that and give it a whirl.
I wonder if there are any MacOS drivers for the PS/2 ports on the Starmax CD as well. Or were they're intended just for CHRP spec to run Windows NT, OS/2, Solaris, or AIX? I did notice that one PS/2 port was more worn than the other. It would be great to have an actual two-button PS/2 mouse for my PC Compatibility card as well.
Share this post
Link to post
installed an older driver (v2.3.1) and I'm now up and running at 500MHz :)
now to mark-up the case...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
