Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10126 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39564
      posts
    3. Trading Post
      53108
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      499
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45986
      posts
    2. Mac II, Quadra & Centris
      13106
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7962
      posts
    4. 68k PowerBook
      9872
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2672
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13740
      posts
    4. PPC PowerBook & iBook
      8967
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7398
      posts
    2. Newton
      1066
      posts
    3. Software
      17464
      posts
    4. Hacks & Development
      18622
      posts
    5. Peripherals
      14548
      posts
  • Posts
    • I'm sure that works well, too. I just figure there is always an off chance that some ancient copy of Stuffit is sitting on any said machine, and having the archives in original format would just make it easier.
    • The Performa came without a PRAM battery. I was under the impression that without the battery it would chime but not produce any video; and that the "jumpstart" method would work for the missing PRAM battery (but not failing caps).   I'm mostly irritated by the voltage breakdown; it's obvious that the computer won't boot when instead of +5V there are less than +2V. Anyway, a complete recap of both supply and logic board is probably in order.
    • More strangeness... front brightness knob does nothing.   Focus turned all the way clockwise makes a more or less normal focused picture. Anti-clockwise becomes unfocused but also increases brightness Cut-off has very little effect and can not be increased to show raster lines (unless Focus is also 100% anti-clockwise) Width and Height controls on the analog board work as expected.   All caps are replaced (JDW's Mouser cart, thanks again!). I have desoldered a lot of passives such as all the potentiometers, any resistors that seem related to the front brightness control. Checked carefully for dry joints and resoldered some. Everything seems OK. Is this symptomatic of some major component such as flyback or TDA1170 having issues?
    • Folks, let me be clear.  MacEffects is worthy of your consideration.
    • I should clarify here, I have 2x IIfx machines, and I am interested in 2 sets of 4 (128MB total).
