Jump to content
ants
Fun with colour on my SE/30
Recommended Posts
2 minutes ago, PB145B said:
That’s wild! Did you ever make a fully-working Mac out of it?
Not yet, it's sitting under one of the benches with the rest of the compacts vying fo attention. Gotta find out if the neck board offset PCB adapter is technical possibility or just make the damn thing and try it. Comment in the thread for any more info to keep this one clear.
Share this post
Link to post
Share on other sites
Keen to see updates on this project! Did you manage to unfry the LCD controller or get a new one?
I was doing some googling to see if anybody had successfully managed to fit a color CRT inside of an SE/30 and found this thread, which is inspiring to say the least. I've managed to secure a 9" color SVGA CRT that may fit, if not with some modification to the back of the Mac case (which is fine, I've got empty spares). Now I just need a Radius Pivot IIsi card to get color out of the SE/30...
Share this post
Link to post
Not yet unfortunately - life has been too busy. However I did receive some more resin & rubber in the mail to make a new mold of the CRT screen - I'm going to try including the mounting tabs from the original CRT so that the LCD can easily and cleanly mounted inside the Mac.
I'll just need to find some time!
Share this post
Link to post
Hooray! If my incoming CRT doesn't properly fit the case without severe modifications, I'll be relying on one of your CRT castings :p best of luck.
Share this post
Link to post
Looking to install an LED screen in my Mac SE/30 as well. Not sure about the casting but I'd certainly throw down some shekels for proper mounting hardware to avoid irreversible case modifications and glue!
Share this post
Link to post
Hi all, thanks for your ongoing interest - however, I've decided not to continue with this project. As cool as it was to see a colour screen in an SE/30 - for me personally I feel the original B&W CRT is a big part of what makes these old machines so special. Staring at an LCD in a SE/30 just felt wrong, which is why I haven't been motivated to keep going with it.
I also own a Mac Colour Classic - it's Trinitron CRT is wonderful and this machine was always made for colour.
Share this post
Link to post
Hi ants,
I'm in Melbourne and would be interested in continuing the project if you were willing to sell your LCD?
Thanks
JB
Share this post
Link to post
Sure - PM me and we can sort something out.
Share this post
Link to post
I hope this project gets picked up by someone else, while I love the CRTs in these compacts, its also so cool to see one running a colour display and this is so much better than just sticking an iPad into a compact enclosure. Good luck to whoever continues this, I'm eager to see it progress! :rambo:
Share this post
Link to post
Ah damn, sorry to hear you're not continuing :`(  it makes sense though, you're right about the black and white screen being part of its personality and appeal - but to me the SE/30 would be the ultimate compact mac if it had colour capabilities, so I'm going to press on! 8-) The CC and CC2 are awesome (especially Mystic modded), but there's something lacking in their general case design. I've always liked square edges I guess.
Should I make another thread or keep posting here? Either way, @ArmorAlley sent me a Lapis ColorServer PDS/30-17 and I just got it working with a driver from the net:
Unfortunately it appears to be outputting a sync-on-green signal which isn't supported by any of my monitors, except for this huge old Hitachi LCD TV. I'm hoping the 9" colour SVGA CRT I've got coming (should be here before mid October) can support SOG but doubt it will. In which case I'll have to fork out some dough for a sync converter.
Another issue is the tube length. I'm 99% sure it won't fit inside the SE/30's case, but I have a spare semi-crappy SE bucket that I'm happy to cut into for the sake of science.
Failing that, I'd like to buy one of your resin casts @ants, or attempt to make my own if you've gotten rid of that pressure chamber you made.
Share this post
Link to post
Can't you turn on B/W in the color settings? I'm more interested in the LCD aspect than anything else. Reduced weight and power consumption, more space for airflow, little-to-no need to hack apart the shell, and a nice crispy picture with no seizure-inducing flicker!
Share this post
Link to post
I really hate it when people replace CRTs with LCDs in situations where it's completely avoidable, especially in things like arcade machines. In this instance though, it would be in service of enabling a Mac to do something it normally can't, so I'm fine with it. That being said, the 9" CRT has priority and I've just purchased a cheapo sync converter that should do the trick.
Edited by DeChief
Share this post
Link to post
I have a standup MAME cabinet that had a HUGE Sony TV as the arcade monitor.  I recently replaced it with a Dell LCD.  For games, the Sony TV was sort of ok, but for everything else, like when I actually had to boot into Windows, or using choosing games from the list, the TV was so blurry, it was a major PITA just to use the thing.  The LCD is so much more crisp, and I can run it at a higher resolution, which is helpful.
And I sure won't miss pulling that super heavy TV in and out; I've moved that cabinet like 10 times, including to a third floor walkup in San Francisco.
Share this post
Link to post
A MAME cabinet is different, I'm talking candy and dedicated. If it just has a PC inside then the whole thing is a bit ridiculous to have in the first place, you may as well hook it up to your living room TV and make some joysticks. :p
Edited by DeChief
Share this post
Link to post
Actually the MAME setup in an arcade cabinet makes a lot of sense.  It really feels like the real thing, albeit with 4,000 games.  My system has 4 position custom arcade controls, so it does a good job replicating the original experience.
But I digress.  My point is that I think the choice is not necessarily black and white.  Given that I have 8 SE/30's, I'd probably opt to replace one of the CRTs with an LCD just to have something cool and different.  I think that beauty is in the eye of the beholder.  Just like we are all in this hobby for different reasons, we all have different level of appreciations for authenticity vs usability.  I have quite a few Apple and Radius CRTs and what not, but more and more I see them as just one more things to fix, so I am often using LCDs with my Macs.
Just all a personal preference really.
Share this post
Link to post
I owned a 2 player (sticks and 6 buttons on each side) 300~ game multicade cab at one point that even had a proper 21" CRT, but it never felt like a good purchase. It went into storage when I moved countries and I sold it the moment I moved back. IMO you lose something valuable when you start emulating things and using modern components in these situations, so I try to use as much old tech with old tech as I can - but yes, that might just be me! What you're doing is fine, it simply feels counter to the hobby as a whole for me, which I'm guessing is because I'm likely younger than the majority of users here. :p
For instance, I'm getting rid of my SCSI2SD after getting a good deal on one of those Adtron SDDS SCSI-PCMCIA devices since it works flawlessly with a PCMCIA-CF adapter in it, all of which is old technology and essentially of the same era as the machines I use it with. I found a cheap external SyQuest EZ135 SCSI drive and sold the SyQuest itself just to use the enclosure for the Adtron, it's really convenient for vintage Macs since I can just pre-load a bunch of CF cards with different operating systems - turns out Yahoo Auctions has great deals on used generic 256 - 500MB CF cards so I've stocked up and am now prepared for any Mac I buy in future.
Getting semi-back on topic, I very much dislike using LCDs with old systems. There was a noticeable amount of input lag when I was testing the Lapis ColorServer, moving the mouse felt like wading through molasses on the 3 LCDs I used for testing compared to the SE/30's internal CRT. I'm not sure how different this would be compared to the LCD that ants was using, but either way, CRT still takes priority. I do have a black and white Radius Pivot SE/30 card if you'd like to swap one of your SE/30's screens to an LCD.
Share this post
Link to post
Here is my arcade machine for reference.  I still need to make a black "mask" such that only the active part of the LCD shows and the bezel is hidden.  The LCD sits behind a piece of slightly smokey plexiglass.
Share this post
Link to post
Alright, finally some progress!
Success! No green tint on a sync-on-green incompatible monitor. How did I do it?
Well I was talking to a friend about sync-on-green and he recommended that I try to find a cheap, used "7053 sync separator", which is a little blue device that takes SoG and splits the sync into Horizontal and Vertical sync for non-SoG VGA monitors (requires its own 6V DC PSU). I found them on some weird website for over $100 USD but they're also on eBay for much less (https://www.ebay.com.au/itm/Software-Integrators-7053-sync-separator-converts-sync-on-green-to-separate-sync/222768549276?hash=item33de0a4d9c:g:V78AAOSwy0JaQCO3&frcectupt=true), so I bought one.
At first the green tint was still there when trying it with all the DB-15 to VGA adapters that I owned, which was a huge bummer. So I gave up for a while and worked on other projects. Then while browsing Yahoo Auctions one night, I came across an adapter by UnimacFly that specifically mention sync-on-green in its dip switch diagram, and bought it. I tested it just then and it works great, here's what's sticking out of the back of the SE/30:
I've tested this setup with multiple SoG-incompatible monitors and they all work perfectly fine, so the chances of this working with the incoming 9" colour SVGA CRT are high. Speaking of which... it's not here yet because the guy I bought it through (the original seller didn't offer international shipping) has been too busy lately to ship it.
Edited by DeChief
Share this post
Link to post
Okay, an addendum to my response: with just the UniMacfly on the CRT in the above photos, it looks fine! But when I try it with the 2 LCDs I have in this room, it has the green tint. I've tried adjusting all of the brightness, contrast, colour temp, etc. settings and it's still there. The only way to make it look normal on those LCDs is with the 7053.
I'll try just the UniMacfly with another CRT later today and see what happens, it's possible this monitor is anomalous since it's actually a 15/31KHz switching one that was originally sold for Acorn computers (made by Microvitech).
Share this post
Link to post
Any chance you could make a similar resin surface for the Color Classic's tube? I'm thinking of making a more dedicated controller board for the TFT if there is interest.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
