Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10106 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39513
      posts
    3. Trading Post
      52997
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      497
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45882
      posts
    2. Mac II, Quadra & Centris
      13029
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7954
      posts
    4. 68k PowerBook
      9855
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2671
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13720
      posts
    4. PPC PowerBook & iBook
      8965
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7389
      posts
    2. Newton
      1066
      posts
    3. Software
      17461
      posts
    4. Hacks & Development
      18537
      posts
    5. Peripherals
      14523
      posts
  • Posts
    • The problem with the SIMM expanders is that you're increasing the number of power-sucking chips by a quite a bit in addition to increasing electrical loads on the memory circuits. I wouldn't likely use them outside of a PC since they often have more power to spare and are more tolerant of weird memory configurations. Plus they're really tall so wouldn't fit well in a compact Mac or most of the II series or similar machines with limited RAM clearance. That said, I got a set of 72-pin SIMM-to-168-pin DIMM expanders in a box of random stuff once. Never tried to use them but they may work in old PCs that can use unbuffered EDO DRAM DIMMS.   Since some people are working on remanufacturing SE/30 boards anyway it shouldn't be too difficult to reshuffle some wires to accommodate 72-pin SIMM sockets in place of the 30s. Maybe flip the ROM SIMM 90 degrees and scooch the FPU over a little? Or maybe just use 4 72-pin sockets instead of 8 to keep things mostly in their original orientations? 4 sockets will still yield 128MB.
    • Can you tell just by the serial number if an Apple Lisa mouse was made for the Lisa 1 or was made during it’s time? They’re probably all look the same for all versions of Lisa but I just want to know.
    • The paths open up in AI9, but the nice type devolves into simple paths. This is doable, below is only a screen shot. Components and connectors on yours are missing, bitmap overlays? line weights and colors are easily fixed. Which pages line up in what order to left and right of this page?       Three layers showing control signals on one layer with data and address buses on the other two for viewing individually might be helpful?
