Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9902 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39189
      posts
    3. Trading Post
      52303
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1481
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45116
      posts
    2. Mac II, Quadra & Centris
      12847
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7880
      posts
    4. 68k PowerBook
      9719
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13671
      posts
    4. PPC PowerBook & iBook
      8941
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7307
      posts
    2. Newton
      1062
      posts
    3. Software
      17334
      posts
      • ttb
    4. Hacks & Development
      18326
      posts
    5. Peripherals
      14405
      posts
  • Posts
    • Congratulations.    Hope the hard will work, but won’t bet on that this time.
    • You can’t kill an SE! Great work.
    • Hmm, did some trials and it seems that the computer starts up (almost) every time if I plug in the battery first. It doesn’t boot up with charger only (I guess this is expected) and I need to RESET + NMI it to get it to boot if I plug in the battery after the charger. So... most probably it works from power mgmt perspective and the sad Mac is because of a bad trace etc.
    • Well, after years of putting it off I finally opened up the PDQ.  It wasn't easy, but easier than opening up an iBook.  I removed the PRAM battery, but I did not replace it with a new one.  While I do like the PDQ I don't use it as often as I do my other PPC Macs.  I only put PRAM batteries in Macs that I use frequently.  I used a stopwatch to time the delay and the result was about 40 seconds under OS 8, both with and without the PRAM battery, so I was off with my earlier estimates.  The PRAM battery wasn't leaking, thankfully, but better be safe than sorry.  I should also mention that I don't use a main battery with this laptop.  The ones I have don't work.  I reduced the RAM from 256 MB to 128 MB and that brought the delay down to about 30 seconds.  I decided to just live with the delay.
    • All I have to say is holy crap, what a lot of time and effort!  More than I would put in!   Kudos!
