Jump to content
Gsbtom
Is my flyback transformer dead?
Recommended Posts
My old college era MacPlus (orignally a 512 but upgraded to a MacPlus) has had blank screen since the 90's. Finally pulled it out of the closet when I was junking a bunch of stuff and figured I'd give it a shot. Re-soldered J4 and J1, and bingo, I've got a screen. The old ProAPP 20S HD works too and boots. Spent an hour or so of playing around with it, turned it off and went to dinner. Sadly, when I went to boot up the Mac later tonight, I have what looks like a classic flyback issue. I was seeing some wavy lines on the edges prior to this, and was preparing to resolder the flyback, but now I've got this (with a burning electronics smell):
Everything on the board looks ok, no obvious signs of burning or anything. This is the flyback, hard to tell if it's bad:
I haven't replaced any caps on the board at this stage (they all look to be ok).
Share this post
Link to post
Share on other sites
The glue on that flyback looks pretty burnt, so I wouldn't be surprised if it's bad. The Dead Mac Scrolls also suggests that the flyback and/or horizontal output transistor are dead. Also, just because the caps look good doesn't necessarily mean they are good.
Share this post
Link to post
Thanks, I didn't know about the Dead Mac Scrolls PDF (I have Pina's other book), that's a super helpful book.
Fair point on the caps, I'll likely recap this board, but need to source a flyback transformer first, which searching for so far seems difficult. Only one I've found is https://www.ebay.com/itm/157-026C-Flyback-157026C-Replaces-Apple-HR-42031/121655780759?hash=item1c533fe597:g:CNUAAOxy14VRWxL3:rk:2:pf:1&frcectupt=true which seems pricey as heck (or simply buying an old Plus or SE which would cost more).
Anyone have any other ideas on sources for a flyback? I've read that you can (and should) replace with a 157-0042C but I can't find those at all.
Share this post
Link to post
It's unfortunate, but at some point Dalbani realized there was a market for those things.  They used to sell the 0042C for $5 on their website, about ten years ago or so.   Their prices steadily crept up through the twenty-teens.   I didn't realize it had gotten that high.  I think Artmix sells a new manufacture version on Ebay, but I don't remember what his pricing is like.
Share this post
Link to post
If I come across an analog board that I won’t be using, I’d definitely sell the used flyback to you for a heck of a lot less than that.
Share this post
Link to post
Looks like Artmix hasn't sold anything on eBay anyway for over a year.
Let me know. I don't mind spending the $$$ but obviously would prefer to spend less... :)
Share this post
Link to post
So an update: I ordered a replacement flyback from Dalbani (grrr $$$), a replacement for Q3 (found a BU406D at arcadeshop), and a set of replacement caps.
Pulled the old flyback. Two different angles from it, can't see any obvious burning, or tell if it's really fried or not.
Pulled and replaced Q3 with a BU406D. I'm suspecting that Q3 may have been the true culprit here, as the plastic broke apart when I gently tried to pry it off the heat sink. The heat sink (not pictured), was slightly discolored, but not severely.
Unfortunately, I pulled up a trace on this. Note to self, fully read Pina, I'd forgotten that I needed to twist the heat sink's holder tabs to get the heat sink off. This patch I put in is really not my best work. I'm a novice solderer here.
Installed the new flyback. The new one from Dalbani is labelled (incorrectly I'm guessing) as "157-026-C". It does fit, however, into the same outer ring of holes that 157-0026-B was in.
Power on test, success!
I was able to adjust the vertical centering, but unfortunately, the screw in the horizontal pot appears to be missing, and the pot itself looks torn up inside.  No idea if I did that years ago or if it was done during a previous repair years ago. It's not perfect, but good enough.
Put it all back together, and booted the hard drive. Crystal Quest was probably my favorite game back in the day.
Introducing my son to retro Macintosh games.
Lastly, hooked up the FloppyEmu board, and backed up the hard drive. It's very old and I don't trust it to last forever, plus the FloppyEmu came with a bunch of neat software to play with (including some games I don't have).
Things still to do:
  1. Install 4MB of memory, well, because. On order.
  2. Clean slight corrosion from battery older and install new PRAM battery. On order.
  3. Left shift key is still wonky. I pulled it apart last week and found a total hack job on the board underneath, but oddly enough not on any trace connected the affected shift key. I resoldered the shift key pins and it now sort of works. Needs more investigation.
  4. Pull the floppy and give it a good cleaning. It does read the one floppy disk I have (that was left in it for 30 years). Looks like the last time I used this was when I was using it to help test Netware network stuff in the early 90's, as the disk is a Netware Macintosh Developer's Kit Disk 1 of 2. Go figure.
  5. Recap the analog board.
Share this post
Link to post
Wow, looks like a nice and bright CRT! Good job.
Theres a guy who sells Plus and earlier style keyswitches on ebay, pretty cheap too if ya need some. I have a couple extras too.
Edited by Johnnya101
Share this post
Link to post
The last time I ordered from Dalbani, they had an assortment of BU-406D transistors on their website (not on Ebay).   So you might have been able to get them all at one source.   Nice job on the repair.
Share this post
Link to post
Thanks all!
I'll look into the key switch if I can't get it to work reliably. For the most part it's fine, I'm going to try a little WD40 in it to see if that clears it up for good. For reference, this is what I found on the keyboard logic board.
Not my handywork! This makes me wonder where I got this keyboard from. As this was originally a 512, I would have had the original smaller keyboard (which I no longer have, or at least haven't seen it in years, along with the original power and SCSI cables that came with it). I'm wondering if I "liberated" this from my school's junk pile or something, or bought it used from the shop when I did the upgrade.
On the floppy repair, it does read disks, but won't eject them (paperclip ejecting works fine). I'm guessing a good head cleaning and lubrication is in order. What's the best thing to use to lubricate? I'll also check the eject gears too.
Share this post
Link to post
Is the floppy the 400k or 800k since I know you said this was an upgrade? This is a big difference. I take the 400k drives apart, take the mechanism completely off and then soak it in WD-40. For the 800k drives it becomes quite a bit trickier to get all those pieces off and cleaned. You really have to completely disassemble the drive to do it, so if a drive works mostly, but stick sometimes, I just leave it. I still try to get everything off that I can (mainly the top) and then soak as much as possible in WD-40 while actuating all of the mechanism. Nothing else will penetrate enough to clean the joints. White Lithium works well once it's been cleaned and for the rails and stepper, but not with getting it unstuck. I'd be guessing it's a gearing issue if it's not ejecting at all. In my experience it should eject partially if it's a lubrication problem. I do have a spare eject motor should you need one.
Share this post
Link to post
Also your keyboard is off a plus. The standard 512 didn't come with the numeric keys and I don't know if they even sold the keyboard then as one unit (the num pad was available separately). That was standard with the plus.
Share this post
Link to post
Looks like it's an 800k drive, judging by the size of the one floppy I have (779k formatted according to Finder). And it's ejecting now, albeit it seems like it's straining a bit, so looks like I might be able to clean it up and get it fully working without much effort. So looks like the eject motor's ok. Might be an issue with the gears, but won't know until I inspect it more closely. Given that the 512 would only have had a 400k by default, I'm wondering if I got the 800k drive during the Plus upgrade...
On the keyboard, yeah, I definitely got this after the fact. When I originally got the Mac, I got a nice case for it, which had space for the computer, the original keyboard, mouse and external floppy. The Plus keyboard sticks out the top (so you can't quite zipper it closed) as the case wasn't made for it obviously, heh. I do remember the external numerical keyboards, pretty sure the Mac's in the school's computer lab had them, though pretty sure I never did. I may have had an external floppy, though that's probably long lost.
Other fun stuff: I found a folder labelled CS231 folder on the hard drive, with Turbo Pascal and Lightspeed Pascal, and a bunch of Pascal school projects still there. It's been 30+ years since I've written any Pascal code, though (all C#/Java these days), so it's kind of neat looking at 19 year old me attempting to code.
Edited by Gsbtom
Share this post
Link to post
The M0110A keyboard with numeric keypad and arrow keys could be purchased separately. It cost $129 in 1986. The Macintosh Plus Keyboard Kit (P/N M2519).
Quote
This photo shows that it is an 800K drive:
Edited by Dog Cow
Share this post
Link to post
5 hours ago, Gsbtom said:
Oh interesting, didn’t realize you could tell visually like that.
The give away is this little shiny metal guy that the red arrow is pointing to:
When it's out in the center, then it's a Sony 800K drive. When it's at the right side, near the emergency eject paperclip hole, then it's a 400K drive.
Edited by Dog Cow
Share this post
Link to post
That is a good catch with the drive, I didn't notice that. That is a giveaway. I don't know a situation where I'd have a good enough picture with a disk in to see that, but interesting to know all the same.
I know the keyboard was available in 86 since that was the 512k e/mac plus, but was it available before that with just the plain 512? I haven't seen an A model from before then. When I say 512, I mean original 512, 84/85 not the 512e.
The 800k drives are a lot more of a pain to fully clean. I disconnect the springs and then pull the top part of the carriage assembly off and spray that heavy with WD-40 and then use my pen to apply it to the bottom mechanism attached to drive body while sliding it back and forth. Doing that usually improves it enough to consistently eject.
Share this post
Link to post
No, that keyboard was introduced with the Macintosh Plus in January 1986.
Share this post
Link to post
Finally got some free time yesterday to continue working on this. Replaced the battery, cleaned out the little bit of corrosion on the positive terminal. Installed the 4 MB of RAM. Sweet, now I can run Civilization! Squirted some WD-40 into the troublesome left shift key and let it sit overnight, as of this morning, seems to be working flawlessly. For now anyway, looks like the keyboard issue is solved.
Next, the troublesome floppy drive.
I was surprised at how relatively clean and dust free it was. Guess leaving it in the Apple bag for 30+ years was a good idea. Pulled it apart, cleaned both of the heads. Figuring the eject gears might be a problem, I pulled it apart to inspect.
Gears are all intact, so I pulled the top plate off,
Again, remarkably clean. Cleaned and greased up everything here.
That's much better, everything's sliding nicely now. I opted against pulling the heads out. The head rails looked clean, so I carefully just q-tipped in some more grease on the rails. If I muck up the track zero sensor, I'm basically SOL as I literally only have one working DD floppy.
However, still no luck with the eject. In fact, it didn't even appear that the eject motor was even engaging on eject. I could see the heads move to the right spot, but the motor never appeared to engage. For grins, I figured I'd check the connector solder joints.
These look ok, except for maybe the bottom one, but I couldn't tell if that was the light or if the solder joint was bad, but I figured it couldn't hurt to touch them up. Quickly realized after this that I need some smaller solder tips. Way smaller. And much better vision than I have. I cleaned up the mess I made out of this.
I was kind of out of options here. As a last ditch, I pulled the eject motor again, and pulled all the gears off to see if at least the motor was turning.
Surprise, surprise, once the gears are off the motor actually engaged. So, cleaned and greased up the gear posts, and voila, I've got a working eject mechanism!
One question: I did watch a couple of YouTube videos on this (super helpful on seeing what pieces did what), and all I watched suggest that I should be aligning the eject pin to 12 o'clock (that's left on the above pic), mine's aligned to 11:30 it looks like. I was adjusting this when I was trying to get the motor going, but ended up putting it back to where it was during my diagnosis. Any reason I can't just leave it? Or is it better to truly line that up? I'm not sure here, as the 800k disk I have does seemingly reliably eject (it's been so long that I don't remember how a brand new drive ejects).
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
