Jump to content
TechEdison
SE/30 nothing happens when powered on
Recommended Posts
There isn’t much else to explain except that literally nothing happens when powered on. I know the analog board and crt are good because I tested it with another board.
Picture of the board can be seen below.
Where  do I start? I’m sure even if the caps were bad it would do *something*
Edited by TechEdison
Share this post
Link to post
Share on other sites
That's some bad rust right there around the floppy connector.
So it does happen like nothing nothing? No fan, no harddrive spinning nothing? Could be a short somewhere if it really does nothing at all - normally it should be flupping or ticking though even with a short.
Caps should still come off though and everything needs a good clean and visual inspection. There are some vias that don't look too good, they need to be checked.
Edited by Bolle
Share this post
Link to post
Yea I think that would be my next step. Oh by the way @Johnnya101, that floppy connector housing didn’t last long lol. I think I could’ve peeled it off with my bare hands. One of the screws snapped while removing it but oh well.
To confirm, nothing happens at all. It’s rather strange. I’m surprised that my ultra-corroded board had more success.... it even displayed something on the screen!
Share this post
Link to post
An update: connected the speaker on both boards. The corroded nasty one made a sort of noise when powered on (no chime, no ram). The gold socketed one was silent.
Share this post
Link to post
Well, I know for sure that corroded board is missing at least one or two parts that have fallen off, probably an IC or two is damaged, and many traces need to be repaired. You're not going to get much farther with it than what you've done.
I'd love to see a photo of it just to see what was under all the gunk!
Edited by Johnnya101
Share this post
Link to post
Yes it’s missing quite a few components. Not too worried about that.
After cleaning  off most of the garbage the traces are actually not as bad as I expected. It’s still got a long way to go but it’s getting there. At the moment I actually have more hope for that board than the other one lol.
913EC21C-E48B-4385-A3B2-590ABC2D89C2.thumb.png.9dc9802b41b3105c4c7bb88c4a3b4118.png27C17755-BB79-4FC1-BBC9-A3AB27660414.thumb.png.6c6bdf8dfd15a55ae5806890842e8e17.png50B26DD1-837E-42B5-B324-700D7FFDB3DA.thumb.png.7e9d2d07f704f440f76eaaa710313504.png7E7D8C8E-D833-40C9-B7C3-1320E57FF8E5.thumb.png.3c1523ab10ff7204b18198b2aab4943c.png
Share this post
Link to post
Yeah, doesn't looks too too bad. I had a guy interested in maybe buying that board plus an SE/30 and showed him a photo and he's like no way that will ever be saved. I'm like, well, I've seen worse. Let's see if you can make it happen :)
Might just have two more se30s put back into circulation
Share this post
Link to post
FOUND OUR PROBLEM!
thanks to reading the thread posted by @techknight I did some poking around and sure enough, L14 is completely missing! Gonna grab that off the other SE/30 board and see if I can get this one fired up.
im also missing c74 and r35 (though r35 looks like it was never there to begin with). Hopefully they are still on the other board.
Share this post
Link to post
Yay! Should be easy now. Probably should get the board a deep clean and new caps, turning it on probably "energized" the cap goo.
Told you you could probably get a working SE/30 out of them. :)
Share this post
Link to post
That was after washing the board. It worked for a couple minutes and then failed again and is doing what it did before.
When it was working though, it chimed and everything. Even the sad Mac without rom or ram.
Share this post
Link to post
9 hours ago, Johnnya101 said:
Cool! What was the issue?
In total: missing components, cap goo, no ram. And of course, broken crt. It was obviously from that case.
Salvaged parts off the corroded one and gave it a good wash. Haven’t tested inputs yet. The floppy drive didn’t work so I’ll have to tear into it and clean it.
Share this post
Link to post
If you need extra SE/30 parts, let me know as I have a bunch of leftovers from the SF Haul of 2014 I'd like to clean out.
c
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
