unity Report post Posted May 27 The ground system in all connected as one. Share this post Link to post Share on other sites
Crutch Report post Posted May 27 @JDW I haven’t noticed the jitter you mentioned but I will look closely tonight. I also thought the ground system was all connected as one - indeed I just checked and the original Pina volume actually recommended discharging to the chassis near the motherboard (photo, p. 12). (The second Pina, covering the Classic and SE, suggested using the screw near the CRT—but didn’t say why.) Share this post Link to post Share on other sites
JDW Report post Posted May 27 @Crutch thank you for checking the screen jitter. I look forward to hearing your feedback on that. My jitter is not persistent but rather comes and goes. Even the official Apple service manuals for the SE/30 mention specifically to discharge to the ground lug of the CRT in the upper left corner and not to the chassis. Because some service technicians were accidentally grounding to the metal frame of the SE/30 instead of that CRT ground lug, they were zapping their motherboards. And for that reason Apple came out with a revised discharge tool that had a resistor inside — the thinking being that the resistor would perhaps attenuate the voltage spike that was killing the motherboards in cases where the CRT was accidentally discharged through the chassis instead of through that CRT ground lug. And that is the entire basis for my concern about the Grayscale adapter shorting the CRT ground lug directly to the chassis. They obviously did it for a reason, but I want to know what that reason is in light of the CRT discharge implications of presents. None of the official Micron documentation that I can find mentions any dangers associated with CRT discharge grayscale board attached. But that doesn’t mean there isn’t a danger. Share this post Link to post Share on other sites
Crutch Report post Posted May 27 Thanks @JDW. This is interesting to me - how does the CRT grounding lug at top right get to ground (I just looked at mine and still have no idea)? The chassis is connected to the grounding screw of the PSU which is in turn connected to the grounding plug in the wall outlet (or, if you're working on the machine, should ideally be properly grounded through a clip that's grounded to a wall outlet). If the chassis is grounded to the wall outlet, is it really possible to fry the motherboard when discharging the CRT to the chassis? (I could see this being a danger if the chassis isn't grounded to anything, like if a technician is just working on it loose on a tabletop.) Share this post Link to post Share on other sites
JDW Report post Posted May 28 (edited) You are NOT supposed to discharge the CRT with the power cord connected to the wall. This is mainly a safety precaution because if you discharge foolishly and somehow flip the PSU switch with the cord connected, you're in a world of hurt! So always disconnect that power cord before you discharge in the normal way, or just use Professor Tom Lee's trick (Stanford University school of engineering, and author of the Classic Mac Repair Notes) and turn up the display to full brightness while powered on and yank the power cord, which discharges it quite nicely. READ THIS about why NEVER to discharge to the chassis ground. The ground lug in the upper left corner of the CRT attaches to the metal belt that wraps completely around the rim of the CRT and is not directly connected to chassis ground. Not all grounds must be the same ground. How then does the CRT get discharged? Well, think about a capacitor. You can discharge it without connecting its ground lead to ground, right? Right. You need only short the leads together and you get the spark (never try that on really high capacitance values though or the cap might blow up -- 1000uF or below is best), and the spark indicates the capacitor discharged, just like the spark or pop you sometimes hear at the CRT cap when you discharge the CRT. So because that CRT ground lug is NOT connected to chassis ground (and in turn, NOT connected to earth ground via the 3-prong power cord), there is no voltage spike that would travel through chassis ground and potentially zap the motherboard. (READ THIS, CRT Safety - 31) HOWEVER, the Micron Xceed Grayscale adapter affixes to the CRT Yoke and it's single ground pin splices two thin black wires (why so thin relative to the stock wire, I do not know), one wire leading to the CRT ground lug in the upper left and the other wire leading directly to chassis ground, which goes against everything I've heard about what you should or shouldn't do in a compact Mac. To be honest, I've been a bit afraid to run my Grayscale setup without the chassis ground connected (which is an important test, I think) simply because Micron did that for some reason. I doubt disconnecting that one ground would blow up the yoke board because the other black wire still leads to the upper left CRT ground lug, but due to the rarity of these boards, I've been too chicken to try it. Perhaps someone braver than I will step up to the task. So for now I can only wonder and take care to remove the PDS card and completely disconnect and remove the motherboard BEFORE I discharge with the grayscale adapter attached. It worries me. I look forward to hearing your test results about CRT jitter. Again, my eyes are seeing only HORIZONTAL expansion and contraction, and that movement is only a couple millimeters so it isn't hugely noticeable, but it is noticeable and is why I wanted to post my experience in hopes of getting feedback from my fellow Micron Xceed Grayscale users. Thanks. P.S. Below are the JPG schematic of the Grayscale adapter compared with the Apple adapter and also a PDF of the patent application. Note though that schematic markings on the patent don't perfectly match the JPG schematic. The JPEG schematic is correct. The 4 caps in yellow are the electrolytic capacitors that probably should be replaced. Grayscale_video_conversion_system.pdf Edited May 28 by JDW Share this post Link to post Share on other sites
Crutch Report post Posted May 28 (edited) Thanks for that explanation - and just to be clear so nobody thinks I am crazy, I was not suggesting fiddling around with an SE/30’s innards while it was plugged into the wall! I was referring to grounding mat setups that involve grounding the mat to a wall outlet, with presumably the chassis sitting on the mat, but I realize now I was very unclear. I just used my SE/30 for half an hour and saw no sign of screen jitter — if I observe any, I’ll let you know. By the way, while repairing my Micron kit recently I checked the electrolytic caps you marked with an in-circuit ESR cap tester and all seemed OK. Not sure how definitive that is however. Edited May 28 by Crutch Share this post Link to post Share on other sites
JDW Report post Posted May 28 No, you were clear, but because there will no doubt be a self-professed CRT expert who will cross this thread and start telling me I don't know what I'm talking about, I put that piece of information in my previous post. Seriously, I've read such posts in this very forum by people with decades of CRT experience AND who also have had no major issues discharging compact Mac CRTs and they feel that plugging the cord into the wall is the right thing to do because of the earth ground, when in fact it isn't. So I was trying to drive that point home so there won't be future debate on that. Please let me know if your screen jitters when you have time to check it. Thanks! Share this post Link to post Share on other sites
Bolle Report post Posted May 28 Disconnecting the wiring harness from the neck board will disconnect chassis ground from the tube. Just unplug that one connector before discharging the CRT and you will be fine. I personally only discharge the CRT when I have to remove the anode cap. The logicboard and any PDS cards that were in the machine have already been removed from the machine at that point anyways. Share this post Link to post Share on other sites
JDW Report post Posted May 28 @Bolle Thank you for the advice, but can you please tell us WHY Micron spliced the ground of the Grayscale Adapter Yoke PCB with one thin wire leading to the CRT Ground Lug (upper left corner screw of CRT) and the other wire leading to the same chassis ground screw as the PSU? Keep in mind the Apple Yoke board does NOT do that, using only 1 thick wire from the yoke board to the Ground Lug in the upper left of the CRT. I really want to know why Micro did that. (See schematics and other technical info from my earlier post.) BTW, I discharge the CRT when I need to remove the Grayscale yoke board to swap it with the Apple stock CRT yoke board. It would be unwise to do such a swap without first discharging the CRT. Share this post Link to post Share on other sites
Bolle Report post Posted May 28 14 minutes ago, JDW said: It would be unwise to do such a swap without first discharging the CRT. There shouldn't be any serious HV exposed on the back of the CRT so you don't really need to do that every time you swap the neck board. (I don't :P ) Not sure why they did connect those two grounds in the first place though. How is this done on other later compact Macs? CC, LC5xx? Do they share one ground for everything? Gotta take a look at my spare Apple CRT neck board to see what's going on. Share this post Link to post Share on other sites
JDW Report post Posted May 28 @Bolle Since you have no fear, fire up your SE/30, then power it off and unplug the cord. Rub your fingers across the Yoke board while still attached and see if you get a shock. If no shock, then you're absolutely right about there being no need to discharge the CRT! I don't know about the Color Classic or even the Classic because I don't own any compact Mac newer than the SE/30. But again, my grayscale adapter question is two-fold: 1. Why did Micron use such THIN WIRES to run from the Grayscale Yoke board to the Ground Lug and to the Chassis Ground? (The stock Yoke Board's Ground Lug wire is very thick!) 2. Why did Micron care to connect the Ground Lug ground wire to the Chassis Ground in light of the fact Apple did not do that and Apple makes it very clear in their own technical documentation to discharge CRTs ONLY to the Ground LUG and never to the chassis. Indeed, it was because technicians failed to heed that advice that Apple had to come out with a revised discharge tool with internal resistor to limit the damage that would occur to the motherboard when discharging the CRT -- apparently it would fry motherboards. Share this post Link to post Share on other sites
Bolle Report post Posted May 28 Just checked... the CRT ground frame is connected to chassis ground with the original neck board in place as well. If you look at the original neck board you can see that there is only one big ground plane that connects all grounds together. They just didn't splice it together (because there is nothing to splice as all wires are soldered in) so it's not that obvious as on the Micron board. Splicing that wire into the harness was probably cheaper than having it soldered to the neck board. Share this post Link to post Share on other sites
JDW Report post Posted May 28 @Bolle Thank you for investigating that. But that opens up the even bigger question of why Apple, in their official documentation, says specifically to discharge ONLY to the Ground Lug in the upper left cornet of the CRT and NOT to the chassis ground? Why did connecting the old discharge tool (or a screw driver with wire attached) to the chassis ground fry motherboards? Why then did Apple create the new CRT discharge tool with resistor to lessen the voltage spike in the event technicians turned a blind eye to Apple's advice and grounded their discharge tool to the chassis anyway (instead of the ground lug)? The only thing I can think if us that there would be more resistivity in between the ground lug and the motherboard ground than if you would to use the chassis ground instead. More resistivity would lessen the spike that ultimately killed motherboards. Would you agree? Share this post Link to post Share on other sites
Bolle Report post Posted May 28 If you think of the CRT as a big capacitor then the ground lug is the shortest path just like in your "just touch both legs of the cap"-example. That's what you want to do when discharging. When connecting to the chassis ground the remaining HV has to find it's way to the CRT ground (through the analog board to the neck board and possibly through the logicboard as well if that's the shortest path depending on where on the chassis you connected the tool). As soon as you are using a tool without a resistor to prevent sparks it is possible that HV arcs over somewhere on its long way. If you have the chassis connected to ground on a power outlet that could help as the HV doesn't have to travel all the way back to the tube but can just go down the drain Share this post Link to post Share on other sites
JDW Report post Posted May 28 @Bolle Thank you for the reasonable explanation. That makes quite a lot of sense. Now what is your reasoning on why Micron choose to use super thin wires instead of the thick wire the stock Yoke board uses to the ground lug? And why not just use one thick wire to the ground lug and forego that other thin wire to the chassis ground? Share this post Link to post Share on other sites
Crutch Report post Posted May 28 Thank you guys for this interesting discussion. @JDW I looked extremely carefully at my display last night. I could see no horizontal jitter at all, I even held the edge of a piece of paper up to the left edge of the display to make sure it was absolutely still. Realizing you said the issue was intermittent, I kept an eye on it for a while, but saw nothing. (Then I played Glypha III for a while ... great game! Mostly playable on a grayscale SE/30 if you know what you’re doing, even though it really needs 640x480... I wonder what John Calhoun is up to these days.) I do see horizontal distortion when I significantly change the overall brightness of the display (for example, start with a blank desktop then open a large white window). But I am pretty sure that’s normal with these CRTs (at least, I also see this on my Plus which obviously doesn’t have an Xceed). Hope this helps. If you decide to recap, let me know if it fixes the issue. I may do the same preemptively one day. Share this post Link to post Share on other sites
Bolle Report post Posted May 28 36 minutes ago, Crutch said: I do see horizontal distortion when I significantly change the overall brightness of the display Mine is doing that too but only in GS mode. Share this post Link to post Share on other sites
JDW Report post Posted May 31 On 5/28/2019 at 9:25 PM, Crutch said: I looked extremely carefully at my display last night. I could see no horizontal jitter at all... Two nights ago, I noticed some minor horizontal jitter on my SE/30 even after removing the PDS video card and restoring the factory SE/30 Yoke board. I tested again last night with my video camera on for 44 full minutes, but the jitter never appeared. I was reminded though of another separate problem of lockups during cold boot, regarding which I created this new thread. I will try to capture the jitter on video if I spot it again. Worrisome that it happens even with the stock yoke board, since that board doesn't have any electrolytic caps on it at all. Share this post Link to post Share on other sites
JDW Report post Posted June 4 (edited) I finally caught my horizontal jitter on video WITH THE STOCK CRT YOKE BOARD installed, during Tetris game play at the end of Video#2 which I posted today in the following thread: Not a single person has given me the courtesy of a reply in that thread, so if anyone in this thread has ideas, I am eager to hear them. Thanks. Edited June 4 by JDW Share this post Link to post Share on other sites
Crutch Report post Posted June 4 (edited) @JDW I just saw it at about 43:35 in your second linked video. That is a really weird and noticeable effect and I have to say I have never seen anything like it on any of my compact Macs. Sorry this isn't very helpful information, I'm sure one of the more wizardly people here might have a better idea what's going on! Edited June 4 by Crutch Share this post Link to post Share on other sites
JDW Report post Posted June 4 Thank you for the reply, @Crutch. Even though you can't help me, your reply shows people still participate in this forum! I must admit, the lack of replies does get me depressed. Hopefully, someone knowledgeable will be able to shed some light on what possibly is going on. Thanks. Share this post Link to post Share on other sites
Byrd Report post Posted June 4 1 hour ago, JDW said: Thank you for the reply, @Crutch. Even though you can't help me, your reply shows people still participate in this forum! I must admit, the lack of replies does get me depressed. Hopefully, someone knowledgeable will be able to shed some light on what possibly is going on Plenty do participate, perhaps tone back on unnecessary posts such as these? Share this post Link to post Share on other sites
JDW Report post Posted June 4 Please define "tone back" and "unnecessary." If you mean you aren't thrilled by my being tongue-in-cheek provocative, that's fine. I've been in forums and in BBS's since the 1980's and one thing I find true is that being provacative pisses some people off but it always gets folks to participate in the end, ultimately leading to useful information that betters the community as a whole. And let's face it, we do this for a hobby and sometimes we don't pay attention very well. Feisty comments attract attention even more than YouTube videos do, apparently. Ultimately, I'm looking for a solution which can not only benefit me but whomever else has the same problem in the future, as per the fact that the words are written in an open forum. And toward that end, if you have any specific thoughts to share, such would be very welcomed and helpful, @Byrd! But even if you don't have any help to offer, thanks for posting and letting me know you're following the conversation! Share this post Link to post Share on other sites
JDW Report post Posted June 6 I put my Micron Xceed Grayscale adapter (yoke board) and Color30HR PDS card back in using my spare Analog Board and tested for well over an hour. No horizontal jitter. So it's clear the jitter came from my other analog board, even though it was recapped at the same time and with the same capacitors as this other analog board which has no jitter. I also swapped the flyback on that other analog board (the one with the jitter), so I'm curious as to what component on the board it could be causing the jitter. As to the freezes I've been getting, those continue even with the new analog board. I've not yet moved back to the stock ROM since it too me a while to secure my ROMinator II MEGA in this motherboard. But since the motherboard is recapped along with the SONY PSU, it must be either the ROM or the socketed Daystar 50MHz 030 PowerCache accelerator causing the freezing. Even so, when the freeze happens, I can then shutdown for 20 seconds, then flip power ON and it won't freeze after that, so long as I keep the machine ON. It's a crazy problem. Share this post Link to post Share on other sites
