Jump to content
PotatoFi
Macintosh SE FDHD No Video or Raster
Recommended Posts
Hey 68kmla! Newcomer here, I hope this type of post is appropriate. I've been looking for a good compact Macintosh community... this looks like it might be the one!
I've been wanting to own a compact Macintosh for a couple of years now, and I decided to tackle a restoration project by buying a project machine. I ended up getting a Macintosh SE FDHD in nice physical condition, but while it chimes and sounds like it's booting, the display is completely dark.
Here's what I've tried so far:
  • Checked brightness knob
  • Checked CRT neck board for proper seating (did not fully remove and reseat)
  • Reflow and check J1 connector on the analog board
  • Test resistor at R22 (Per Dead Mac Scrolls, page 150)
  • Measured voltages at the floppy connector, and found 12.00v, 5.00v, and -11.84v
  • Checked all analog to logic wires for continuity (Per Dead Mac Scrolls, page 26)
  • Checked for CRT glow at the neck, and there is a tiny orange glow (but I'm not exactly sure what to look for)
  • Replaced PRAM battery (unrelated, just maintenance)
  • Blew all of the dust out (unrelated, just maintenance)
  • Did retrobrite on the case and it came out beautifully, looking forward to retrobiting the front but I'm waiting until the machine works
At this point, I'm at a complete loss as to what to try next. I'd really like to revive this machine. Any ideas? Anything I'm missing?
Edited by PotatoFi
Share this post
Link to post
Share on other sites
Hi there,
Welcome to the 68kmla. Thanks for liberating this poor fella. The FDHD is a great compact to start up with. You'll be able to create disks with your modern computer in no time. Before we go any further, did you dispose of the PRAM battery? If it's silver and red do it NOW before something really bad happens. If it's blue, purple or any other color get rid of it as it's not needed and it's probably dead anyway.
After that done...
Is the CRT glowing at the back? It might be very faint but if it's there, you have high voltage and that's good.
I would reflow (or even replace, that tends to work better) every solder joint on the analog board. I know you already did J1 which is a common problem on those machines but I had the same issue with a Plus several months back and it turned out another joint was bad. So I would replace the solder on J1 and reflow/add a little more solder to the rest of the joints.
Also can you check the joints on the logic board connector for cracks? It's also pretty common for a joint to go bad there. And video gets to the analog board via this connector.
Last but not least, there might be a short on the CRT board. But only check this if you have high voltage. If you don't, there must be an issue with the Analog board.
Also, be careful around CRTs. Those things pack a lot of juice.
If you still can't get it working I'm sure someone here will come to your rescue with a spare analog board to do some testing.
Good luck!
Edited by BadGoldEagle
Share this post
Link to post
If you have a scope then you will need to use it. If not, get one.
Need to verify all your signals are coming from the logic board properly. the video signal, and both horizontal and vertical drive.
Once you know thats good, you can trace that signal all the way through the analog board because the schematics are available. Then you willl find out right away where the video signal is dying off.
Share this post
Link to post
Any recommendation for the oscilloscope? I need one of those as well. Neil from RMC uses an app on his iPad and an adapter with prongs connected to the lightning port. It looks fancy but does it really work I wonder?
Share this post
Link to post
Sounds like an Oscium oscilloscope. I've worked with them directly. Very good guys. They've worked black magic to get that gear working on the stringent power that a lightning port provides. Wish I had one!
Share this post
Link to post
I dont know if it can handle high voltages or the bandwidth needed to handle what your testing. Most of those systems only work in the audio spectrum, but again, it depends on the design of the setup.
Share this post
Link to post
Thank you! And yes, I selected the FDHD specifically for the 1.44 mb floppy drive. Seemed like a great low-cost alternative to the SE/30.
As for the PRAM battery, absolutely. I tossed it first thing, and replaced it with a "leakproof" battery from RetroFixes. If I ever plan to store it long-term I will remove the battery.
Quote
Yes, there's a tiny orange glow. Like a butane soldering iron. Does this indicate that the flyback transformer is operational? My knowledge of CRT's is very limited, it seems like a lost art...
Quote
The joints on that connector look absolutely beautiful. I did use my multimeter to check for continuity from the logic board to the analog board and they all checked out. Do you still recommend a reflow?
The solder joints on the analog board look super nice. Should I still do this? I should probably invest in a solder sucker.
I can also buy a known-good analog board on eBay for about $40 including shipping. Would that be a smart move, or should I hold off?
I have a friend with a scope, and know-how to use it. Will give this a go soon.
Thank you both VERY much for your help.
Share this post
Link to post
I would still reflow those joints. Mine looked perfect but they weren’t.
You’ll need a solder sucker sooner or later. The PSUs in those Macs are getting weaker by the day. You’ll probably have to recap it sometime in the near future. So a solder sucker is definitely a good investment.
I’m no CRT expert myself but you most certainly have high voltage, so the flyback should be good. If reflowing everything on the board doesn’t fix it, you’ll have to go signal hunting.
I don’t think the logic bord’s bad (but I’m no expert unlike techknight). Thankfully the SEs don’t have a complex video circuit (compared to its bigger brother the SE/30). IIRC it’s incorporated in the GLU logic chip and this one doesn’t go bad very often. But the joints on the LB connector can be bad. So I would reflow them too.
Again that’s what I would do. It may not help at all. Techknight’s method is definitely the best.
Share this post
Link to post
Great news! The Macintosh SE is happily humming next to me on my desk with a working CRT. The culprit was a disconnected leg on a component, specifically this filter at F1. The damage was obscured by a glob of hot glue.
And here it is after it's first working boot in who knows how long:
I hugely appreciate your help with this. I managed to write some floppies for it with dd on my MacBook Pro + USB floppy drive last night and reinstall System 6.0.8. It felt great to play Sim City on it for a few minutes. I'm impressed that everything works, including the floppy and hard drives. Future plans for this machine:
  • Retrobrite the front (I've already done the back)
  • Install 4 MB of RAM
  • Install the PRAM battery (I forgot to install it in my haste to put it together)
  • Perhaps take apart and lubricate the floppy drive
Share this post
Link to post
Bah, look what I've done. I didn't want to start another thread for this one because it's so dumb. I was pulling things back apart to retrobrite the front, lubricate the floppy drive, and install the PRAM battery when I did this:
Now I know to reach in there with some pliers and pinch the clip instead of just trying to pull it off. The picture barely shows it, but there is a small wire protruding from the hole. Am I okay to just screw that screw back in there, and allow it to make contact with the wire? Ever had this happen?
Share this post
Link to post
Congratulations for fixing it ... and breaking it short afterwards :-x Don't worry, we've all done it.
But I've never seen that happen before though.
If nothing fell inside the tube, you should be able to just reassemble the two pieces and put it back together.
Were you trying to remove the front panel? If you were, here's a tip for you in the future: You can pick up the analog board and the CRT as one piece (so you won't have to remove that anode cap again). Just loosen the A/B and you should be able to remove the two CRT screws hidden just under the board. Then lift up the whole thing and set it aside.
Oh and if you really plan on using the most of your FDHD, you should consider an SCSI2SD and/or a Floppy EMU. The hard drives are on their last legs and SSDs are much faster!
Share this post
Link to post
Nothing fell inside the tube, as soon as I realized what happened I became extremely paranoid about keeping that from happening! There's exposed wire in there... I think I'll wrap it around the screw and put it back together very carefully. I'll get as good of contact as I can.
As for the hard drive, I have a friend with a SCSI2SD 5.1 who has offered it to me as a gift. I will absolutely be replacing the hard drive with it. I'll probably do a 4MB RAM upgrade at the same time.
I just checked my retrobrite progress on the front panel... it's looking absolutely beautiful. I'm going to leave it under the light for a couple more hours and call it done. Then I just need to lubricate the floppy and reassemble, and this thing is ready for Oregon Trail, Lemmings, and Sim City!
Share this post
Link to post
Before I put it all back together... I think the potentiometer on the brightness knob is dirty. Range is sorta dim to pretty bright. Is that normal operation?
Share this post
Link to post
Ok, it's all back together! Here's what the front looked like before cleaning and retrobrite:
IMG_0530.JPG.569fa0cc1c161ce0458d9db15cccc24a.JPGo
And here is the final result:
Retrobrite notes:
  • Cleaned with Dawn dishwasher detergent, water, and a soft toothbrush
  • Scrubbed marks off with a wet paper towel and baking soda
  • Thoroughly painted with Salon Care 30-Proof Hydrogen Peroxide Cream, wrapped in plastic wrap
  • Placed under a CFL "Lizard" UV light for ~10 hours (room temp, no extra heat just the CFL)
  • Rinsed, reapplied cream and rewapped
  • Exposed for another 8 hours
Notice that the Apple logo was unaffected. I'm super happy with it! It's humming away on my desk with AfterDark running right now, so cool. Despite having a 1.44 MB floppy drive, getting files to it is a bit of a pain. Disk images are easy, I can just write those with DD in the Terminal in my Touchbar MacBook Pro. Individual files have to be moved over to my iMac G3 running OS X 10.4.
Plans for it:
  • 4 MB of RAM
  • SCSI2SD if/when the hdd fails
  • Figure out some "cheap networking", either over serial or with a 56k dialup server on a Raspberry Pi
Share this post
Link to post
I love it! By the way, you probably can get files to it by accessing the USB FDD with a program called CiderPress. I don't know about a mac, but it works on a Windows PC, CiderPress opens the physical drive and lets you insert a file.
I'm a little concerned as to why your desk is so empty :)mine is packed with random Macintosh stuff...
Share this post
Link to post
Thanks for the tip! It bugs me that I can't just use my daily driver MacBook... I guess I can run CiderPress in a VM. As for my desk... I like to keep it cleaned off but don't worry, I have a ton of old game consoles and stuff in my office. :)
1 hour ago, joethezombie said:
Great job!  It’s nice to see a fellow Idahoan!
There are dozens of us! Dozens!
Share this post
Link to post
Very nice. Congrats.
Might I suggest the Floppy EMU for large (or small) file transfers? I have one myself and it's great. I'm not sponsored, just a happy customer.
I don't use floppies anymore (which in a way spoils the experience) but when I really want to go full retro, I use it to duplicate floppy images to real floppies. It takes about 1 minute. The SD is hot swappable, so I just leave the EMU connected on the back of the (main) Mac, take the SD out, copy an image from the Mac garden, copy it to the SD, plug it back in, mount it and use the classic MacOS to duplicate it to a new physical disk. You can also use it to emulate a 2GB hard drive.
But you can totally get away with a SCSI2SD too. It's about the same except you can't emulate floppies and you can't use it on non SCSI macs of course. Since I have quite a few far too many I prefer the Floppy EMU.
I wish I could just plug a regular xFAT formatted USB stick to a SCSI emulator and mount the 'stick' on an old mac as an external device. Basilisk and Sheepshaver can "mount" HFS+/APFS folders to OS9 (it basically emulates a Unix drive ). It should be possible to create such a device but unfortunately I don't have the programming skills to do that myself...
Share this post
Link to post
Cheater! But seriously... the Floppy EMU is awesome, looks like a great piece of kit. Idk if I need to get files back and forth enough to justify the expense, I think I'll keep a Windows or Linux VM around for the occasional floppy disk write . It really is too bad that there isn't a simple application for modern macOS that can read/write HFS floppies. Even if I could use the floppy drive with Mini vMac, that would be awesome... swapping floppies around is just so much fun (no sarcasm).
Edited by PotatoFi
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
