Jump to content
Sign in to follow this
westcoastech
Macintosh SE Accelerator PDS Add-on Cards
Recommended Posts
Hi Everyone
I have two add-on cards for the Macintosh SE and/or SE/30 that I hope to get a bit of help identifying. I had confirmed they worked when I removed them from the original machines a long time ago but I did not record the information and I no longer have a machine to use at this moment.
From the searching I have done I found another thread on here actually and this one card was best guessed to be a Mobius 030 card but I thought would be best to include it here and could maybe have it identified for sure. The one card was missing a few chips in the picture on the other thread. The other card has the writing Color SE30 A13 Generation X and 1989 Memory Plus COGAM-4 REV B in the lower corner.
Here are the pictures of the possibly Mobius 030 card
IMG_2314.thumb.jpg.407a2c995cdf8562818d011febb7bcb4.jpgIMG_2315.thumb.jpg.e0a384b0044091a7cb5f0a708ff2ad4f.jpgIMG_2317.thumb.jpg.9a9c21a81dd2855604b7dca1882e5278.jpgIMG_2318.thumb.JPG.75863efa94e716e774278ee15f83cc85.JPGIMG_2316.thumb.JPG.9b06105f0b258383ebd96adac9262195.JPG
This is the Color Card
IMG_2310.thumb.jpeg.900fa550eb9fd58f3d616700748b76fb.jpegIMG_2311.thumb.jpeg.65b02a9b02b00b7eb448c910937699be.jpegIMG_2313.thumb.jpeg.cf17e5ec93ec88e8bbb2e5cde4e19cbe.jpegIMG_2312.thumb.jpeg.14109adabf2b7e400ac758e5c58165ab.jpeg
Thanks for any help everyone!!!
Share this post
Link to post
Share on other sites
The first is a Mobius 030 card. I have one which works well now.
I think that a missing oscillator on my card is only necessary to use a FPU at 20Mhz. See the jumper next to it.
Driver http://vintageapple.org/macdrivers/accel.shtml
Virtual software to take into account extra RAM on the card http://vintageapple.org/macdrivers/accel.shtml
With System 7.0.1 all is OK, with Mobius driver and with Compact Virtual loaded.
-> Mobius 030 (v4.99) + Mobius Display + Compact Virtual 3.0.2 in System Folder/Control Panels
-> Mobius 7.01 Fix + Mobius Sound + MobiusInit in System Folder/Extensions
It looks like you have the cable for the screen.
I do not have it, I tried to make one but without success. I have a signal, but no picture.
Do you have the screen?
Can you make a diagram of the cable?
Edited by gpbonneau
Share this post
Link to post
Hi guys
Thanks a lot for the replies, sorry for the delay, bit of family business.
Here are a couple pictures of the bus connectors on each, they are different sizes, hopefully this gives a bit more info
GlabhkUZDvyCCzZLmz7SYA0ezpvsDAL9HCq0_LZh
rALmxCBCZyOJfPuLqC1gFTfZtXWrAyt-eah5fXZj
Here are some pictures of the connector for the Mobius connector gpbonneau let me know if you need more pictures or if you still need a diagram of the wiring.
wKNa67WHe4UnZL9mqH8hkLdcTfUrW-mkmepCeaBS
zNW8kfoN3YYiLveEHZyb-hV6QDFdXQw-kToZM-LQ
uezihZBDu9ugMLv-23noIRO43w1-r7h-QVcgf97w
7ZPGOuCeJOVB1HgvLRVpcXX75zaqsCJu3BTx6pzq
IEZeHo1-KPKcqHyl1OS6IUYL7lf4vLWLg-ThWGx7
m8MlqblcygaPu75K36C6PFtGxsI2jlIgHRoJ2nFr
j-o4cpxUDbXRvOqrTH1PNdPR-PgaKsNNtlfxzU-W
mJVNc3Y__cQuoWNSNLbDYRQRT56hvCAWqJlrxn5Q
63TMTJ0QYbmmDjWptzQqek_H9lCuN2EWz2btM7hg
jIWfyv2IO4aWPhJgvsr9uOQMI8yU0XQtXJZc-dM0
Share this post
Link to post
Definitely not VGA compatible output. Mobius was a monitor vendor, the monitors supported are listed on that great .jp site.
A couple of us were trying to get a similar Radius TPD card to work with a non-card specific display. I made minor progress hooking it up to the RGB BNC connectors on a multiscan TPD. Info there might give you a start. Dunno where the thread is. I didn't start it, but maybe I can find it if you can't.
Share this post
Link to post
Have the same. I tried to plug a VGA LCD monitor (which works very well on all my Mac) I can move cursor and window on the second screen but I don't have picture.
I think you are right, it is not compatible, with the first option (Mobius One Page SE) on my LCD monitor, which detect a signal, I can see something on setup OSD (1152x870, sync H68.8 and V75.0), but the screen remain black.
With the second option, I have "out of limit" on screen and noting on the OSD.
And according to Mobius manual :
Edited by gpbonneau
a
Share this post
Link to post
Hi guys
I do not have a monitor from that machine unfortunately. I bought the SE on eBay and didn't even know it had an add on card until it arrived and it took it all apart to clean the machine. It seems it was a type of wild west with these accelerator and add on cards back in day?
Does anyone have any ideas or info on that second card perchance?
Share this post
Link to post
Hey westcoasttech,your second card looks like a video card for an SE/30, judging by the size of the bus in the pictures.  Kinda reminds me of the Interware VD-R1 video card that I have that I can't quite get to work!  I also have a Raster Ops 264/SE30; I've never seen something like what you've got here.
If you're interested in selling it, let me know :-)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
