Jump to content
Sign in to follow this
cfriberg
What is DP8? - Macintosh Analog Board
Recommended Posts
It's been recommended to replace DP3, DP4 diodes which I am ordering.  They look fine except the solder joints look burnt.  What I can't find is DP8.  It's a little diode maybe similar to DP3.  I can't tell because it burned up.  The 1st picture is just my board model.  The 2nd shows DP8 under that blue cap.   What is this called, so I can order a new one?
Thanks for your help!!
20180817_131212.thumb.jpg.575fb2631c6cf0e74fd313605e62c76c.jpg20180817_122339.thumb.jpg.532155bcbcfd2de23d5bce003a0cd67e.jpg
Share this post
Link to post
Share on other sites
removed one from the board to check the markings,
the diode is a
PH-73D
the resistor next to it is 10 ohm
Edited by marcelv
Share this post
Link to post
Took me some while to find the exact diode type. It's a philips BYD73D. In fact, I just registered just to write this here. You won't find anything by searching for "PH-73D", so I looked through some old philips components catalogues.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
