Jump to content
Welcome Back! - Read Me First Read more... ×
zezba9000
Macintosh Classic capacitor types
Recommended Posts
Looking for the highest quality longer lasting capacitors I can use to repair classic computers (such as my Macintosh Classic or LC, etc).
I heard SMD lifespan isn't great and my Macintosh Classic suggests this to be the case.
What is the best set to get out of these below? Are all types usable on the Macintosh Classic?
SMD
https://www.amazon.com/Capacitors-Assorted-Values-Electrolytic-Assortment/dp/B0778LX66Z
SCT
https://www.amazon.com/NTE-Electronics-SCTD476K16-Capacitor-Capacitance/dp/B008UFX7Y8
https://www.amazon.com/NTE-Electronics-SCTC105K50-Capacitor-Capacitance/dp/B008UFWVEA
TD
https://www.amazon.com/NTE-Electronics-TD47M16-Capacitor-Capacitance/dp/B0089ESYQ6
https://www.amazon.com/NTE-Electronics-TD1-0M50-Capacitor-Capacitance/dp/B007Z7RRBG
My computer symptoms are no sound / chim, HD isn't detected. Everything else seems fine after washing motherboard.
Thanks for any suggestions!
Share this post
Link to post
Share on other sites
If you're in the US, you should look to buy from mouser.com or digikey.com. You can get exactly what you need. I used mouser. The individual capacitors are very inexpensive. I recommend reading through this forum and buying all of the recommended caps, diodes, etc for both the motherboard and analog board. They charged $7 in shipping, which ends up being the biggest expense. Better to overbuy on capacitors then pay multiple shipping charges.
Share this post
Link to post
I have Amazon prime so don't normally have to pay shipping when I order from there is why I look at it first (but I hear ya). This is to fix a Classic board that wasn't in the best shape (after the lithium ion battery caused some damage [but stuff seems like it will work as it mostly does after washing the board]) so I'm going to attempt this myself. I think I have enough soldering experience to do it right or will learn a lot from this attempt. Will do some practice runs on other crap boards first though.
I have a SE/30 I just picked up as well. Board is in good shape so I will probably have that one professionally done by maccaps.com as I care more about it.
Edited by zezba9000
Share this post
Link to post
Michigan, I think. He did an SE/30 for me and it was good work, though it required some extra investment to track down a bad sound trace.
I have heard that allcaps (in Florida, I believe?) also does good work.
Share this post
Link to post
Last I knew (haven't done business with him since he got banned), he was in Southfield, which I think is a suburban area somewhere near Detroit.
c
Edited by CC_333
Share this post
Link to post
c
Why would he be banned?
Share this post
Link to post
I'm not exactly sure, but I think it was because he broke several rules repeatedly, and the admins finally had enough.
I guess you could contact any of the admins if you want more details. I'm not sure it's wise to continue discussing it here, so that's all I'll say on the matter.
c
Share this post
Link to post
So I replaced the capacitors on my Macintosh Classic and washed motherboard.
Everything works BUT one major issue! The hard drive isn't detected. What capacitor(s) are used for scsi? Maybe I did one wrong.
Screen turns on and is bright.
Boots ROM quick.
Sound now works.
Boots from floppy drive just fine.
Doesn't detect HD (the physical disk works, tested it on SE/30 to make sure).
Any idea?
Edited by zezba9000
Share this post
Link to post
12 hours ago, Skate323k137 said:
The schematics for these older machines should be in the old apple repair manuals. You could start there, or alternately just follow traces near the scsi connector.
Do you have a link to where I can find those docs? They on these forums?
Share this post
Link to post
So didn't know this but Macintosh Classics have a rom simm with the full blown OS 6 on it.
idk whats wrong with scsi but because of this, I can boot the computer and read disks with my Floppy Emu or external disk drive.
This is good enough for me as I wanted this computer just to try out classic C/C++ code I compile with a newer mac.
WooHoo. Also fixed my SE/30 sound as well from what I learned!
Share this post
Link to post
So I have to eat my words, I could not find the right schematic for you :(
The other older compact macs like SE have easy to find ones in books and pdfs, I thought the Classic was among them.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
