Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9948 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39273
      posts
    3. Trading Post
      52507
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1485
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45247
      posts
    2. Mac II, Quadra & Centris
      12887
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7890
      posts
    4. 68k PowerBook
      9739
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2638
      posts
    2. PCI Power Mac & Performa
      5859
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13690
      posts
    4. PPC PowerBook & iBook
      8953
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7317
      posts
    2. Newton
      1063
      posts
    3. Software
      17354
      posts
    4. Hacks & Development
      18364
      posts
    5. Peripherals
      14442
      posts
  • Posts
    • In my basement, along with the 2.6 you were looking for. I will try to see if I remember how to make images of them. Send me a message with an email address and I will try to get them to you.
    • IDK about the LCI/II/III as I never got the card I have working on my LCII beyond maybe installing the drivers and a green light of some sort.   But I will note that I had similar trouble with my Power Mac 6100/66 not playing nice with a more modern 10/100 Mbps (Fast Ethernet) switch or hub, whereas interposing a 10 Mbps hub in between it and more modern hardware solved that problem (probably a similar auto-negotiation/duplex problem).
    • I wouldn't necessary rule out sudden failure of some critical PSU component, these machines are 25 years old after all.   A multimeter is okay for simple voltage, resistance, and continuity checks, but not generally useful for determining if capacitors are dead (at least not while they're in-circuit) or the overall health. IDK if there are any good test points, but it wouldn't be a bad idea to verify that the inputs/outputs of the regulators seem as expected and that where the electricity enters the board the voltage also seem correct. Also capacitors don't have to look bad or be leaking to be dead/out of spec, or at least that's my understanding.   Does it matter whether you leave the battery out or not?   P.S. I really doubt it matters here, but compressed air is pretty cold coming out.
    • Nope but it looks super cool.  Gonna have to crack it open when it comes to figure out what it is.
    • Perhaps your problem has mostly to do with cable select...   https://en.wikipedia.org/wiki/Parallel_ATA#Cable_select
