Jump to content
Von
SE/30 Power Supply: Recap or ATX?
Recommended Posts
JDW, Thank you so much for your help here.  I really appreciate it.  I watched your Analog board recap video and it was awesome, helped me out a ton and I learned a lot!
Edited by thxkbye
Share this post
Link to post
Share on other sites
@thxkbye
Thank you for your kind words.  I am actually putting the finishing touches on a new Analog Board recapping video right now, which focuses on the Mac 128k~Plus.  It has an interesting section that shows what a bad Flyback transformer looks like in the dark, so stay tuned for that!
Share this post
Link to post
1 hour ago, thxkbye said:
I was able to buy a SSP-250SUB, it ran me $78 with shipping.
Higher than $49, but much cheaper than $109.  Do you have a link to the seller?  It might prove useful for some people, since I've not yet heard back from Seasonic.  Thanks.
Share this post
Link to post
Either will work as an SE/30 PSU.  I must say though that is the first vendor I've seen who is selling the 300W at the same price as the 250!  Wow.
Share this post
Link to post
Back to square one looking for a PSU.  That ithardwarehub cancled my order, said the PSU was broken then raised the prices to $250.  Avoid!
I am considering my options now and just getting one off ebay...
Share this post
Link to post
If it is indeed “broken,“ how then can they write raise the price to $250?
Still no reply yet from Seasonic Taiwan. :-(
Share this post
Link to post
I think im going to try to get an SE with a Sony PSU since I already have the cap kit and back burner the ATX until a source becomes available.   I have a feeling ordering a PSU from china right now is going to take a long time.
Share this post
Link to post
Sorry for all of the posts, but I have been thinking about this issue with sourcing a PSU for the SE line, and thought of something.  I was thinking about other devices that I have used that would likely have a small form factor PSU inside in the range we need.   I thought the original xbox might be worth looking at, they made ALOT of them and that machine likely uses an ATX PSU but it is only a 98w psu.   Working with that idea in mind I was looking at the Playstation 3 PSU fat and slim models, as well as the Playstation 4 and Xbox One console PSUs  These parts are very cheap and readily available.
Here is the wiki which shows all Playstation 3 PSU specs.   https://www.psdevwiki.com/ps3/Power_Supply#Power_Supply_Unit_.28PSU.29
Also there are a number of mini-itx power supplies out there as well.  What should I be looking for besides at least 250w with a 12v and 5v rail?
Share this post
Link to post
Use the SONY CR-44 PSU as a frame of reference for the voltages and minimum Current output you will need:
+5V: 6.0A
+12V Sweep: 1.25A
+12V Disk: 2.1A
-12V: 0.5A
Sweep and Disk are not isolated, so you could drive both with a single +12V power line rated at 3.35A or higher. And no, a -12V line rated at 0.3A is not acceptable, in my opinion, since the -12V line of the SONY is 0.5A.  Even if a power supply has +5V, +12V and -12V outputs, if the current for any of them is lower than described above, it would be unwise to choose such a replacement power supply.
Another benefit to the SONY CR-44 PSU is that it's complete fanless, unlike any replacement PSU you may be considering (including the SEASONIC).
Share this post
Link to post
5 minutes ago, thxkbye said:
One of the comments below that product listing says this:
Quote
...this thing sounds like a harrier jet about to vertically take off
Physical size is another issue to consider:
  • RP-FLEX-350W = 193mm x 152.4mm x 58.4mm
  • SEASONIC SSP-250SUB = 150 mm (L) x 81.5 mm (W) x 40.5 mm (H)
We know the SEASONIC fits nicely inside the metal PSU enclosure of the SE & SE/30, and using that enclosure is nice because it has the power switch built-in along with the power plug.
Share this post
Link to post
17 minutes ago, thxkbye said:
... i would replace any fan with a noctua fan, which are usually extremely silent.
Yes indeed.  You can see and hear a 60x25mm Noctua in my SE FAN VIDEO here.
Share this post
Link to post
Going to see about an SE dual floppy tomorrow. I hope it has a Sony PSU inside, i'll use the cap kit on it and hope i can get a ATX solution for it sometime down the road. It's only 30 bucks, id buy it even if it didn't so its worth a shot.
Share this post
Link to post
I'm sorry, but I wouldn't get near cheap PC PSUs like that with a long stick.  Super generic, and not UL listed.  So if it burns your house down that might be a problem.  I would recommend getting a FLEXATX PSU from a reputable brand.  I would get an SE/30 PSU from eBay.  You can get a sony one for about 40 USD, and recapped, it shouldn't be a fire hazard.
Share this post
Link to post
I picked up this SE today for $30.   Owner said he had not tested it had no plans for it.  But it had a black power switch, it powers up and attempts to boot so at least i can use it to work on my SE/30 while I work on getting an additional PSU.  I have the Sony cap kit so I will do that immediately. Look forward on finding a quality ATX solution with you all.
Share this post
Link to post
Ah, the memories!  I worked as a repair tech for MicroAge in Fresno, CA during my senior year in high school in 1989.  The SE was still being sold then, but the hot item in the store I gawked over was the lovely IIci!  Totally unaffordable for me at the time ($6k+ retail), but boy I wanted one.  Ultimately, I ended up buying a IIvx in '93 with a college student discount -- a machine Apple notoriously killed off only months later.  A year after that, I recall spending $1,000 of my hard earned pennies on a Quadra 650 logic board upgrade for it, which made it a very usable machine.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
