Jump to content
JDW
Modern PSU for the SE/30
Recommended Posts
@Crutch Did you measure voltage levels (specifically, the 5V line) at the Floppy connector and at your internal HDD power connector when you had your Turbo040 inside?  I ask because in my experience, prior to my epic blunder which caused my Turbo040 to stop working, I would only get freezes with the Turbo040 when there were software incompatibles.  That's a lot of software that just locks up with an 040 but which works fine with an 030 processor.
Share this post
Link to post
Share on other sites
On 2/8/2019 at 12:46 PM, ants said:
@Crutch your solution of wiring the soft power of the Seasonic to the original switch is very elegant - I wish I had of read your post in more detail before I did my upgrade!
That is how I wired mine as well. The only downside though is I'm still hesitant to leave the computer plugged in when I'm not using it. If I had wired the PSU AC power to the physical switch I probably wouldn't think anything of it as turning the Mac off would mean it's off, full stop.
Share this post
Link to post
38 minutes ago, superjer2000 said:
...If I had wired the PSU AC power to the physical switch I probably wouldn't think anything of it as turning the Mac off would mean it's off, full stop.
That's how I have my SEASONIC wired.  When the mechanical switch is flipped OFF, the PSU is 100% OFF and has no possibility of ever going ON.  I didn't think anything negative about doing it that way since that is basically how the stock PSU works.
Share this post
Link to post
There's definitely pros and cons of both methods. I think for a novice like me, wiring the soft power would have been easier and less scary. I guess I'm just paranoid!
Although I was wondering how hard it would be to get the soft power running to the power key on the keyboard?!?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
