Jump to content
Sign in to follow this
Rasterops 8/24 xli help
Recommended Posts
I have a Rasterops video card that is clearly labeled 8/24 xli that I'm trying to use in a Iici.  These boards are supposed to put out 24-bit color, but I am only getting 8-bit.  The options for higher bit output are greyed out for the driver software and the monitors panel shows only through 256 colors.  Software is installed and works.  The Rasterops Paintboard I am currently using puts out 24-bit color, and when I use the xli, I get the RAM disk option.  Is there a setting or a switch on the board that I'm missing that enables 24-bit color?  I see no switch on the board and only one jumper, the presence or absence of which doesn't impact this issue.
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
