Jump to content
Sign in to follow this
twillkickers
Connecting to Internet on an LC II
Recommended Posts
I am having trouble getting my LC II to connect to the internet. I am trying to connect directly via ethernet using an Asante MCiLC network card. I've installed all relevant drivers, and I am using Internet Explorer 4.0.1. I am using System 7.5.5. When I connect my Ethernet cable directly from the LC II's network card to the router, the upper light on the network card blinks quickly. However, when i open up Internet Explorer 4.0.1, I get errors such as "Data transfer error (-28)" and "The website could not be found" for every website I type into the address bar. I have set my TCP/IP settings to DHCP. Am I missing anything? Any and all help is appreciated! I have been working on this all day and now I am very tired :p
Share this post
Link to post
Share on other sites
22 hours ago, olePigeon said:
DHCP is hit or miss with older hardware, usually miss.  Your best option is to configure TCP/IP manually.  Don't forget the DNS.
Thanks for the tip. I tried configuring manually. I entered a static IP in the IP field. I entered my router IP in the "router" field and I entered 8.8.8.8 and 8.8.4.4 as my DNS (Google DNS.) However, the same issue still seems to be happening. Am I missing something? Should I try different settings?
Share this post
Link to post
If you're still not having any luck, sometimes you have to put an older switch between the computer and the newer routing equipment.  I put an old Netgear 10/100 8 ports switch between my vintage machines and my newer router.
Share this post
Link to post
+1 to the above suggestion. Old ethernet cards can be notorious for not wanting to auto-negotiate with a modern router switchport. Granted at this point if you don't have an old hub lying around it can be sort of hard to find one.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
