Jump to content
digitalrampage
PowerBook 150 - screens all destroyed?!
Recommended Posts
On 1/4/2018 at 11:08 AM, techknight said:
Good news is, you can get replacement polarizing film with adhesive. It isnt cheap but its doable and easily fixed if your careful.
Cool! I still have the old display from my Compaq Contura so I may try this.
Share this post
Link to post
Share on other sites
5 hours ago, techknight said:
I think it all depends on their previous life and exposures. I know alot of the PB170/180 machines had tunneling, but mine does NOT so it may have been stored differently.
Reckon it's just down to hours of use; the CCFL gases wear out either end like any other household CCFL when used extensively.
You're right on the polarising film; had a quick look and a small 5 - 10cm x 10cm sheet is $35 - 50.  I wonder if a donor LCD could be used, for example from a cheap generic laptop, cut down?
Share this post
Link to post
"peeling" the film will ruin it. I have tried to re-use old polerizing film, and itll develop lines and marks from "peeling" and the inconsistent remaining adhesive will cause optical obstructions.
Share this post
Link to post
Found a 145 at the office yesterday, exactly the same issue as my 150's. It could only be humidity related, three separate locations, all with the same.
Surely there must be a way to remove, clear off the old adhesive and even just sit the polariser over the top?
Share this post
Link to post
Hi guys, I am sorry it took me so long to take the pictures I promised, but here they are. My collection of powerbooks was kept in two different rooms with our dehumidifier running all the time, because of a health condition. Since I am a chemist, it never even crossed my mind to clean the screens with solvents, so this can't be the reason for the excessive damage. Since last time I checked, the PB520 and Duo 2300c screens got even worse. The bright spot on the Duo 230 screen is not a flash light reflection, it is a polarizer damage. Any ideas of what might been causing the polarizer deterioration?
Share this post
Link to post
Just now, Trash80toHP_Mini said:
YOWCH! Can you see the damage when the 'Books are powered down or do I need to go through my collection and test under power  .  .  .  those that'll power up. :/
You can see it when off.
Share this post
Link to post
Wow, just as bad.. Worse on some. Its like a bacterial growth. The last one certainly looks like mould, but I have a 180c with that "cracked" plastic too. Clearly something bad is going on =(
Share this post
Link to post
Yes, you can see it on the Duo 230 - it looks as a slightly discolored area, but if I have not turned it on I may have not noticed it. On the PB G3 no way to tell - it is only visible when it is on.
Share this post
Link to post
I have a few more which screens are still OK, but I am worried that these too will fail. I wonder if I should stop collecting powerbooks and collect only desktops from now on.
Share this post
Link to post
Why not buy some new film and see if you can fix them? That’s what I’d do.
Share this post
Link to post
My belief is that Apple must have used the cheapest LCD screens they can put their hands on. Nothing else can explain why all my PC laptops are OK - I have about 15 of them, a few Toshibas, Gateway 2000, IBM Thinkpads and NEC. My oldest is the NEC Ultralight, which is a 286 machine from about 1989 and its screen looks great. In fact it was in the same drawer as the Duo 230.
Share this post
Link to post
Dang, that eBay100 pic finally got me to pull one of my PartsBoo100s off the shelf. Looks like two rounds crazed its bulletproof glass. Might have been like that when I got it though as it was pretty beat up, but still  .  .  . :/
But the LCD in PB100 on the AppleDisplayUnit is fine, as is screen of the one I recently got from another member. The LCD from my original PB100 looks brand new in its heavy duty ZipLoc bag home of the last thirteen or fourteen years. The 2300c screen I'd squeezed into its lid is fine as is the screen on my main 2300c machine in the Dock.
Looks like I'll need to go through the entire collection. It's about time I did a head count anyway.
Edited by Trash80toHP_Mini
spellchecking
Share this post
Link to post
I'm 90% sure that Apple didn't skimp on the screens. Indeed, they often had displays (on the high-end models, at least) that were the envy of the portable computer crowd at the time. Plus it's not like knockoffs from FlyByNightVendor.com or whatever were common in the '90s: take apart an Apple display and the LCD manufacturer will likely be Sharp, Toshiba, Sony, Casio, Philips, or IBM. Many of the same panels reside in contemporary PC models, especially when display sizes standardized around the 10-12" era (1997ish).
Anyway the worst of Apple's LCD quality issues didn't start to crop up until LG or Samsung displays started to appear (Defective 13.3" on a PDQ? Pink Pismo? Pink or dead Apple Cinema Display? Guess who made them).
I've really only seen severely damaged LCDs like this overseas. I saw an ADC Apple Studio Display with bubbles in diagonal streaks; I assumed it was from improper storage or cleaning products (my aunt ruined a 50" LCD TV in a similar fashion by cleaning it with ammonia or some other harsh glass cleaner). Years ago I bought a PowerBook 520 and it looked like the display had been dipped in acid, as warped, bubbled, and rusty as it was. I recently bought a PowerBook 160 with a similar screen but the damage was near the battery, which had bulged; I assumed that battery fumes had got to it, but the keyboard and the rest of the case are fine, so I dunno.
Share this post
Link to post
I meant NEC Ultralite.
Share this post
Link to post
22 hours ago, galgot said:
There is a Duo 280 on sale on the bay , seller from Italy. It has the same film screen problem... Seems these films are reaching their ends nowadays... :/
I found the listing! You are absolutely correct - it seems that it suffered from the exact same type of screen polarizer damage as both of mine. Here is the picture that I downloaded from eBay. I am done collecting laptops.
Edited by techgeek
Share this post
Link to post
What would nice to determine is why it happens to some before some others…
Mines have none of these problems so far . I live in a not so dry area , humidity is quite high along the curves of the Seine around here. + I have some spare parts stored in a closed place in the yard, no heat there. And still none of them have these...
Share this post
Link to post
Not me! I love vintage laptops and I will do whatever I have to to fix them. I have already started working on getting the film replaced on my old Compaq Contura LCD. Wasn’t too hard to get the film off but getting that old rotten adhesive off is quite difficult! I’ve found that acetone softens it up pretty well. This *shouldn't* hurt the panel underneath since it’s made out of glass but we’ll see...........
Share this post
Link to post
I hope you succeed - let us know how it went! ... take pictures on each step and post them here, so that those of us who are more adventurous can follow in your footsteps.
Share this post
Link to post
Sure! Here are some pictures of before and after peeling the film off. I haven’t really done much more to it yet but I did put some acetone on there Was able to scrape a small portion of the adhesive off. Not sure when I’ll have time to mess with it some more but when I do I’ll definitely take pictures and post them.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
