Jump to content
krye
400k Drive Repair Guide - A Call to Arms!!!!!!
Recommended Posts
I have a handful of 400k drives in various states of disrepair. Some show signs of life, but don't read floppies, some appear as dead as a door nail. I've searched the internet high and low for a repair guide or how to in the hopes that I'd be able to service or repair these drives. I found one site that offered some tips, but it is out of date and the images are less that stellar.
As far as head alignment, I heard that is some serious business involving an oscilloscope. I'd love to know more about that. If anyone can offer instructions that would be great.
What I'd like to see is this post become the definitive guide for the service and repair of 400K drives. Please contribute how to's, repair guides, tips/tricks and pictures! We love pictures!
These drives are getting harder and harder to find as the years go by and the prices go up and up. We need to combine our collective repair and servicing knowledge in order to keep our 128s and 512s going. 20 years ago, I'm sure repairing these was common. Now it seems to be a lost art.
Thanks.
Share this post
Link to post
Share on other sites
Larry Pina's book 'The Dead Mac Scrolls' has some useful information on fixing 400k, 800k and 1.44Mb floppy drives and a section on how to re-align the heads without the need of an Oscilloscope. That tends to deal with the later drives rather than the earlier ones, but I suspect the procedure is similar.
Well worth getting a copy if you can find one cheap enough.
ISBN 1566 09016 4
Share this post
Link to post
Adjusting the head is in most cases not necessary.
Make sure your drive is complete: check that the pressure pad is still there. Without that, the drive will never work.
Here's how to clean and lubricate the drive.
- Remove the complete top assembly that holds the floppy disc ( release the lever from the eject motor )
- The mechanism will be completely stuck due to old grease that has hardened. Soack the assembly in WD40 for a few hours or if you have the WD40 Spray: spray all the moving parts multiple times, leaving 1/2 hour between treatments, until you can move the mechanism again.
Patience is the issue: do not try to move the mechanism with force, wait until the WD40 has solved all the old grease and dust.
- Once the mechanism is moving smoothly again, then clean all the WD40 from the assembly.
- Lubricate all the moving parts with a small amount of white lithium grease
- Now is a good time to clean the Head: clean it with at least 99% pure Isoprophyl Alcohol.
- Mount the assembly back on the drive and re-connect the lever to the eject motor.
Now try test the drive. First verify that all parts work. Insert a Double Density disc and see if the main motor spins the disc and the head moves.
Also try the eject mechanism.
If everything works, then mount the drive back in it's enclosure ( external is best to test ) and connect the earth wire.
Now try to initialize the floppy disc: If it formats without bad sectors, then the drive is repaired.
If not then inspect the head under a magnifying glass: it it's scratched or damaged then it's beyond repair.
Otherwise you have to adjust the head.
Look at your floppy disk for damage: if the head pushes too much on the floppy disc, then you will see circle scratches on the disc.
Best practice is to set the head as low as possible and keep trying until you can initialize your floppy disc without problems.
For adjusting the head, you needs to remove the PCB at the bottom to get to the screw.
You can find a detailed explanation here:
http://lowendmac.com/tech/after.html
I would not recommend to turn the screw fully clockwise, but do it with little steps of 1/4 turn clockwise until it works.
I know it's a time consuming job, these 400K drives always are....
Good Luck,
Nico
Share this post
Link to post
Sorry for digging up an old post here, but I am having issues with two 400k floppy drives and am curious what your results were.
Were you able to fix any of the drives?
Mine try to read, but fail to read known good 400k disks.
Share this post
Link to post
i have (2) 400K floppy drives
as soon as you power the computer on the seek head comes on and makes this click click click sound…
other then that i went all through the drives mechanically tip top shape.
I bet some I/C on the PCB needs to replaced to fix this issue I'm having.
Share this post
Link to post
Hello all,
I created a Lubrication guide for these 400k floppy disk drives in October after a noticed a fellow member having some difficulty.
https://drive.google.com/file/d/0B6j6P7lBWw-BNHQ4dXRYZkFGdzQ/edit?usp=sharing
I wonder if one of the keepers of the 68kMLA Wiki would be able to upload this guide to the 'Tutorials and Documentation' section of the wiki as I believe it would be a useful resource for fellow collectors! You have my permission to do so!
Share this post
Link to post
Do these drives have the optical sensor?
Share this post
Link to post
Both drives?
They do have a head sensor in the back. I presume for parking/setting initial location. Same type of "red light" sensors in the front that get blocked by a plastic moving tab.
Share this post
Link to post
the mechanics, motors, sensors are all good… been tested with a good PCB… the issue is in the PCB.
i didn't think to check caps… yikes lol… but non of them seem to be leaking :)
Share this post
Link to post
You cant tell by that. Only an ESR and cap meter will tell you that
Share this post
Link to post
Thats why i generally just replace the caps without measuring, an ESR would cost me more than the few cents for the caps :D
Share this post
Link to post
Luckily for me, I got 2 ESR meters. One is analog that i bought. And a digital one that was given to me for a present.
I picked up an LCR meter as well, which is handy to have. They do make ESR/Capacitance combo meters but eh...
Share this post
Link to post
On 12/30/2013 at 12:22 PM, techknight said:
Dont forget these drives are full of caps too
I'm rather surprised no one listed what those capacitors are in the 400k drives, nor do I find any discussions or YouTube videos on recapping them.  So I guess that means I need to do it.  Well, here's the first step:
Big PCB:
3pcs of 47uF 16V, D=6.5mm, H=8mm, Lead Spacing=2.5mm
2pcs of 22uF 16, D=5.1mm, H=8mm, Lead Spacing=2.5mm
Small PCB:
2pcs of 10uf 16v, D=4.2mm, H=7mm, Lead Spacing=2mm
3pcs of 10uf 35v, D=5.15mm, H=6.2mm, Lead Spacing=2mm
0.47uF 50V, D=4.2mm, H=6.2mm, Lead Spacing=2mm (or less)
0.22uF 50V, D=4.2mm, H=5.8mm, Lead Spacing=2mm (or less)
1uF 50V, D=4.2mm, H=7.5mm, Lead Spacing=2mm (or less)
I next need to put together a Mouser Cart with the appropriate replacements.  The key here is to not go beyond the Diameter or height, as many of these caps are a tight fit.  The tallest 7.5mm capacitor on the small circuit board is the absolute tallest you'd want to go.  And don't think about using 5pcs of 10uF 35V, forgoing the 2pcs of 10uF 10V, seeing the Diameter spacing on the circuit board necessitates the two different voltage ratings due to the difference in capacitor Diameter.
Also note that you will need thermal grease for the copper heatsink, as that is used between the copper and the silver metal chassis of the drive.
I'll probably do a video on this once I order and then receive all the parts.  But I've been putting together a capacitor list on Mouser for the last two months, checking all my analog boards, motherboards, floppy drives, GCC Hyperdrive (which has its own PSU, and there are caps on the HDD itself too!), and so on.  It make take me another month before it all comes together and I can start on the video.  Suffice it to say, if a lubed floppy drive doesn't work and the cable and heads are good, it could come down to unstable operation due to the capacitors.  Again, I'm really shocked no one has focused on this.  It's not like the motherboard always needs recapping but the floppy drives are somehow immune.  They have electrolytics too, and many were built in 1984, meaning those caps are now 35 years old in 2019.
Share this post
Link to post
@CharlieFrown
Your hunch is rooted in sound engineering reason.  Why should caps on a motherboard alone go bad after 30 years and not electrolytic caps everywhere else?  ANSWER: They ALL go bad.  So yes, caps alone could create problems for many floppy drives.
I've not opened an 800k drive yet.  My next drive to open is the SE/30's 1.4MB SuperDrive.  For now, here is my 400k floppy drive capacitor list with my Mouser replacement list (none are polymer because I don't have a schematic to know if the super-low ESR would causing timing problems, but all the caps shown below are 5000h @105°C and many have ESR perhaps lower than the stock capacitors, yet probably not too low to cause any problems):
Macintosh 400k SONY Floppy Drive Electrolytic Capacitors
Big PCB:
6pcs of 47uF 16V, D=6.5mm, H=8mm, Lead Spacing=2.5mm (Mouser: UTT1C470MDD1TP)
4pcs of 22uF 16V, D=5.1mm, H=8mm, Lead Spacing=2.5mm (Mouser: UPW1C220MDD6)
Small PCB:
4pcs of 10uf 16v, D=4.2mm, H=7mm, Lead Spacing=2mm (Mouser: UTT1C100MDD1TP)
6pcs of 10uf 35v, D=5.15mm, H=6.2mm, Lead Spacing=2mm (Mouser: UMV1V100MFD1TP)
2pcs of 0.47uF 50V (could be 16V), D=4.2mm, H=6.2mm, Lead Spacing=2mm (Mouser: USV1HR47MFD)
2pcs of 0.22uF 50V (could be 16V), D=4.2mm, H=5.8mm, Lead Spacing=2mm (Mouser: UMV1HR22MFD)
2pcs of 1uF 50V, D=4.2mm, H=7.5mm, Lead Spacing=2mm (Mouser: UTT1H010MDD)
I lack time right now to link up all those Mouser model numbers, and since this forum won't allow me to edit my post many hours from now, just copy the individual part numbers in bold above and and paste them in Mouser's search field to see the capacitor specs.  I spent a lot of time making sure Diameter and Height were appropriate so the replacements would fit.  This is a very important consideration on floppy drives where space is tight!
Share this post
Link to post
Yep.   I fixed my old sprinkler control system by replacing the caps on the main board....
Caps may not be causing all the problems, but everything old is likely to need new caps.
Share this post
Link to post
Hi guys,
I need your advise and expertise here.
Over the past years I have refurbished a few 400k drives. My experience is that they only need to be thoroughly cleaned (especially the r/w head) and lubricated.
I also learnt that the mechanical part of the drive is more delicate than one might think and does not tolerate much variation to the factory set up (position of the frame relative to the head), so you have to be very careful with it too.
However, I have one drive which is working *almost* fine, in the sense that it normally works (i.e. read / write / format / verify disks which are also OK on other drives), but from time to time it throws errors.
Running the sole disk utility I could find around (the "Sonytest" included in the unofficial early System beta relates, either 6.9 or 7.0), low level routines are showing random errors popping up here and there, whereas the same floppy disk results an immaculate run when tested on different drives.
Now, I have the feeling that read / write signals are spurious or low level signal to noise or whatever and I was wondering whether the aged capacitors may have fallen behind the tolerance impacting the signals.
However, I must say that my experience is saying that even after so many years they are still within the range of tolerance.
Any suggestion on how to assess the source of the issue and how to fix it is more than welcome!
Paolo
Share this post
Link to post
4 hours ago, pbertolo said:
Running the sole disk utility I could find around (the "Sonytest" included in the unofficial early System beta relates, either 6.9 or 7.0)...
Can you please post a link to that?
Share this post
Link to post
You can find the disk images on many sites, such as WinWorld or Macintosh garden.
Mind they are unstable and only work on Mac 128K, but they are indeed low level utilities for the 400k drive.
Share this post
Link to post
I have a Mac512k with the original 64k ROMs and a 400k internal drive.  I have another Mac512 with 64k ROMs and 400k floppy drive and GCC HyperDrive (internal).  Why would that software only work on the 128k and not on my 512k machines too?
Are you saying the OS is unstable or the Utility is unstable.  (If the utility is unstable, it may not be such a useful utility after all.  My intent is to test my working 400k drives with it to see if it finds something I am not seeing.)
If you are too afraid to post the direct link to the Macintosh Garden page in this forum for some reason, please PM the direct link to me.  The reason is because I really don't know which disk image(s) you are referring to.  Thank you!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
