Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10245 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3975
      posts
    2. Conquests
      39706
      posts
    3. Trading Post
      53564
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1487
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      511
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      46624
      posts
    2. Mac II, Quadra & Centris
      13323
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      8023
      posts
    4. 68k PowerBook
      9974
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2685
      posts
    2. PCI Power Mac & Performa
      5925
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13771
      posts
    4. PPC PowerBook & iBook
      8998
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7420
      posts
    2. Newton
      1074
      posts
    3. Software
      17544
      posts
    4. Hacks & Development
      18958
      posts
    5. Peripherals
      14661
      posts
  • Posts
    • Alright, I have my copyBits animation stuff working with buttons and menus controlling it. I ended up creating three offscreens, two are for the static sources and one is for the staging area before copying everything to the screen. Might be a little bit excessive but no need to load pictures from the resources for each refresh. It even runs fine on SE/30 with 7.5.5    Thanks again for the help!
    • Thanks for the welcome. My first post. I've tried the Dove 030 accelerator CDEV, to no luck. I saw a post in 2003 about drivers for the 68020 in a yahoo group, but it no longer exists (see post at https://www.mail-archive.com/compact.macs@mail.maclaunch.com/msg08453.html).   This board is strange. It has four 1MB simms on the accelerator, and the SE board has 4 MB simms, but oddly R35 is still present and the Mac finder shows 2MB only. I would have thought that someone who upgrades the RAM would have removed the resistor to allow 4MB.   Still, board was well seated, without the CDEV, it boots into a 68000 at 8MHZ. Here are some high resolution pics.
    • @dochilli funnily enough I have just done that and will try it out later   I'm using a 27C400, which is 512K, so I presume that will be suitable? The image wrote no problems, though I don't know if it needs to be byteswapped or not, but the ROMs I have are erasable so not an issue if they need to be.   Might explain why I see the same with or without the ROM installed. Also got new optocouplers, so I may well replace that because I can.
    • 4.85 and 11.89 should work, but are a little low. Time to recap the AB and PSU.
    • I would think, that it is a problem with the rom. If you get no chime, then the access to the rom failed.  If you have access to a eprom burner you can burn a new rom. Rom copies can be found in the internet.  I own some classics but none had problem with the ram on the logic board.
