Jump to content
Sign in to follow this
nahuelmarisi
Se/30 ram
Recommended Posts
The SE/30 will take 512K, 1MB, 4MB, 8MB and some 16MB 30-pin SIMMs, installed in lots of 4. There are eight SIMM slots in the machine meaning there are two banks of RAM, named A and B. This means the machine can be upgraded to a whopping 128MB total!
1MB SIMMs are quite easy to find (and cheap) but larger sizes are getting a little scarce now. If you wish to be adventurous with your SE/30 I would suggest looking for some of the larger chips as the extra RAM will give a noticable increase in performance. You'll need to install the Mode32 extension to address more than 8MB as the SE/30 has a 32-bit "dirty" ROM. My SE/30 runs quite happily on 8MB, (8 x 1MB SIMMs), which is adaquate for retro gaming and some older apps.
Share this post
Link to post
Share on other sites
I see,
would this work on the se/30:
http://cgi.ebay.co.uk/16-Mb-4x4-Mb-30-pin-SIMM-memory-for-Cisco-4000_W0QQitemZ290169256388QQihZ019QQcategoryZ73321QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also if you say it can be upgraded to 128, but accepts only 16 mb simms or lower, how do you make it go to 128?
Finally, does the logic board need to be removed to upgrade the ram?
thanks for all the help, Nahuel
Share this post
Link to post
... would this work on the se/30 ... ?
That's 9-chip parity RAM from the PC world. The Mac will ignore the ninth chips. However, if you had trawled this Forum before asking, you'd have found that the cheapest (~USD30 per set of four) 16MB 30-pin 60ns FPM non-parity RAM can be had here, and if you do not wish to lash out for 16MB, 4MB SIMMs of the same spec. can be had for about USD10 per set of four.
To make sure that the 4MB cards can be moved to any other Compact AIO if you need to do so, ask for 8-chip SIMMs instead of the 2-chip.
Already addressed.
The MLBs of Compact AIOs need to be removed to do many things inside the Macs, especially if the MLBs are to be worked on. You'll get used to it.
de
Share this post
Link to post
equil, those auctions are in the US, i would prefer european ones. thanks for the help
You'll find 4MB and 1MB SIMMs in the UK. 16MB SIMMs in the UK/EU will be really rare, and much more expensive than from the US. Globalisation is easy: if you trust the seller, bid or buy. For one in four purchases from the US, you will pay import duty. In the long term, buying from the US is cheap.
Share this post
Link to post
equil, you say that using the ram on ebay from the pc world will mean that the 9th chip will be ignored. Does that mean that it would work but instead of 16 mb i would get 14?
Also, then what I have to look for is 30 pin , 60 ns, parity (what does that mean btw?) simms?
thanks
Share this post
Link to post
A byte is eight bits. A ninth bit can be appended to each byte for error-checking/correction of the other eight bits. The ninth chip is for this purpose. A 9-chip "16"MB simm is actually an 18MB module (16MB of user bits, +2MB of parity). If you ignore the ninth bit/chip, you have 16MB of user bits, and zero MB of error correcting ("parity") bits. You do not need a module with parity, but having it won't hurt. As equill said, it will be ignored. If you have the option of not paying for it, then save the money. If you don't have the option, then you get what you can get.
Hope that helps.
Share this post
Link to post
Take it from one who has two SE/30s, three IIcis, a IIcx, a Q700 and two Q950s that can use 16MB SIMMs that you will have the greatest difficulty in finding cheaper 16MB SIMMS of such quality as the above (both non-parity and parity at the same price) anywhere. The postage from US to UK should be less than from US to Australia, which was a miserable USD6 for two sets of four until it recently increased to USD11.50.
You have nothing to fear from a trans-Atlantic purchase but fear itself. The US is naturally the largest Mac market in the world, and for anything that is not uniquely Euro-centric, the logical place to go.
de
Share this post
Link to post
Thanks tomlee for your technical isight.
Equil, I'll give it a try. It's just that I've always got everything (not only mac stuff) from the EU and I'm used to not having any kind of check on my parcels. I'm a bit scared of H&M Customs when ordering stuff from outside the EU. But well, other people have stated that they have had no problems.
Share this post
Link to post
It's just RAM. It's not like you're importing weapons grade uranium.
With the current state of the UK, mothers can't even take bottles of baby milk on planes without them being tested first. It's crazy.
Share this post
Link to post
Correction: EU, not UK. It's still nonsense, but there are signs that the European Parliament is recognising that fact. I've not flown this summer, but is Spain (and possibly others) still asking for passport numbers and addresses to be registered with the airline in advance of check-in?
WRT to the OP and UK customs: I've bought various bits of computer kit from the US during the last ten years. All of it has been "vintage" stuff, and 90% of the time this has been recorded on the customs declaration. Strangely enough, all parcels were sent by USPS so the deliverer in the UK was Royal Mail or Parcel Force. The price that I paid for the goods was between £10 and £500. In total, probably 15 or 20 parcels.
During that time, I have been asked to pay customs duty three times. Other people are less lucky, and large, professionally packaged items are a popular target for customs. Customs duty is a stinker: you pay an inspection charge, which varies depending on the value of the goods and the carrier, but it is at least £5. On top of that, you pay the import duty -- it varies depending on the item, but just use VAT as a starting point.
In the long term, it works in your favour. Occasionally, you get a silly bill before you go to collect your parcel, but it is very unlikely on a small package of SIMMs.
Share this post
Link to post
de
sure a slong as you have the actual means to do that if you are more locally bound then you are just screwed arent you
Share this post
Link to post
Never trade liberty for security. You wind up with neither.
Share this post
Link to post
Just to echo what everyone else has said, the SE/30 will definitely accept 16Mb SIMMs. I know as I managed to get some (here in the UK) and added them to my machine to ramp it up to a very healthy 80Mb. Takes a while to boot but worth it. One thing to note though is that the SE/30 has two banks of RAM (A and B) and you should fit the higher capacity modules into bank A
If you do get stuck, let me know and I'll have a look through my big bag of RAM and see if I've got any 4Mb modules lying around (got loads of 1Mb modules)
Share this post
Link to post
As we know, far cheaper RAM is available than these:
http://www.edgetechcorp.com/store/Products/Standard-SIMMs-(Desktops)/Fast-Page-Mode/30_pin-non_Parity/16MB-5-0v-FPM-30_pin-SIMM--Unbuffered-60ns-8_chip.htm
16MB 5 0v FPM 30-pin SIMM Unbuffered 60ns 8-chip
$17.70
http://www.edgetechcorp.com/store/Products/Apple/Macintosh/Macintosh-SE^slsh30/16MB-Kit-for-Mac-II-Si--Ci--Vi--Cx--Vx--and-SE^slsh30.htm
16MB Kit for Mac II Si Ci Vi Cx Vx and SE/30
$33.16
However, what possible difference could there between these two SIMMs sold by the same merchant that they charge almost twice as much for the latter, though even the former is about twice what it should be?
Is the pricing of the latter just marketing designed to take advantage of those who do not know their machine's memory specifications?
Am I missing something?
Share this post
Link to post
I'm getting a page not found on your first link and did not try your second link, but just from the names, the difference is easy enough to discern.
The first is a 16 MB SIMM. The second is a 16 MB "kit" which is probably made up of four 4 MB SIMMs.
Jeff Walther
Share this post
Link to post
The links for both items work if they are cut and pasted, but not if they are just clicked on since for some reason the highlighting on this forum cuts off the URLs.
The possibility of the "kit" being (4) 4MB SIMMs makes sense, except that the listed weight for both items is identical at "0.04." Perhaps they mean weight per SIMM in the case of a four SIMM kit, though usually it's listed for shipping. I suspect though that you're probably correct.
Share this post
Link to post
'Tis not a stock SE/30!
And trag is correct about the SIMMs I referred to above. My curiosity drove me to call the supplier, who confirmed that the kit is indeed composed of (4) 4 MB SIMMs. My pessimism regarding their ethical standards was unjustified.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
