Jump to content
Recommended Posts
If it helps; I have exactly the same card as ktkm, the sticker in the lower left corner (front) says P34. ©1992 and the same card as in figure 22 in the manual, page 53.
Interesting, I wonder if P34 Rev was the last version of the 68030 PowerCache series? That could explain three revisions and model designation states:
First Rev - P34 designation printed on Silk Screen Layer early on in 1992 - P33 still in production or in distribution channel?
Second Rev - P34 dropped from Silk Screen Layer, but Sticker applied - P33 out of production, but some still in distribution channel?
Third Rev - Sticker no longer applied (no residue on ktkm example) by late 1992 - P33 stock cleared from channel
The main reason I'm curious about this would be the state of my P33:
MC68881RC16B - asynchronous clocking off logic board or 16MHz reference signal on PDS if it works (untested, waiting for an adapter)
MC68030RC50B - Socketed 50MHz 68030
50MHz Crystal Can - factory installed
State of ktkm's P34:
MC68881FE33B - asynchronous clocking off logic board or 16MHz reference signal on PDS if it works at all (untested, waiting for an adapter)
MC68030FE33B - SMT 33MHz 68030
33MHz Crystal Can - factory installed
P33 and P34 are all but identical: WAG, theoretical P33 state:
MC68881XXXX - whatever  .  .  .
MC68030RC50B - 50MHz 68030 as on my P33, but sourced from third party and socketed in place of a factory installed 33MHz part
50MHz Crystal Can - board rework of 33MHz oscillator factory installation done in the field (HACKED!!!!!  [}:)]]'> )
Might be a semi-educated guess more than a WAG, dunno? But sure as schiznit, were it my product that P33 design would become the First Rev P34 with SMT CPU in a friggin' heartbeat.  Gotta stave off the efforts of certain "field upgrade inclined personality types!" [:o)]]'>
Edited by Trash80toHP_Mini
Share this post
Link to post
Share on other sites
There also exists a P341 revision:
So this probably won't work.  I tried replacing a 33MHz can with a 50MHz.  I also replaced the CPU and FPU with 50MHz models.  It caused continuous bus errors.  Looking at the cards, I noticed the cache memory on the 33MHz cards is a slower access time than on the 50MHz parts.  I actually secured some faster cache memory, but have yet to attempt to replace the slow versions with their faster counterparts.  This is on a socketed PowerCache version, so I've been very hesitant to rework it, due to the rarity of the beast.  Perhaps 33MHz is good enough.
Edited by joethezombie
Share this post
Link to post
I've looked for the P34 number on other places before, because the P34 sticker is a bit faded (3 almost looks like 8, but I'm sure it says 34. Everything else matches) so I wanted to be sure - but the P34 is nowhere to be found on the silkscreen.
No, you can not use it with the Asante!  The power pins are in wildly different positions!  You *must* use a DayStar DualPort IIsi adapter with this card.  Don't do that again without the proper adapter, severe damage can occur!
I know the normal PowerCache cannot be used, but I've researched this before and found a manual stating that the Universal version can be used with the Maccon3 IIsi card.
Share this post
Link to post
Unequivocally not.  The MacCon's passthrough is a PDS socket.  The PowerCache requires a Cache socket.  Although they are dimensionally the same, the pinouts are wildly different, especially the power points.
Share this post
Link to post
P33 is the shit!
Same software configuration and adapter (TwinSpark) new PowerCache (Daystar PowerCache P33 50MHz). (Thanks omidimo for helping me out!)
System is stable (no more freezing-up) and works with Power Central 1.3 and 2.0.
Share this post
Link to post
So you have the not so well working PowerCache as a spare now that you have to get rid of?  ;D
Would love to get my hands on one for some testing for when we get our adapter toys ready.
Edited by Bolle
Share this post
Link to post
Hello Bolle,
I’m not ready to part with it just yet, since I still want to test the P33 thoroughly, and perhaps use it the IIcx again. But I could perhaps lend it to you?
If I get it back in one pice  [;)]]'>
Share this post
Link to post
Hi guys.
I have a P33 myself and C40, C43 and C53 are missing!!!!
Can someone test these 3 capacitors and send me value and tension in order to fix my card?
This would be highly appreciated.
Share this post
Link to post
Those are just decoupling caps. Probably in the 100nF range or something.
I will have a look once on of my PowerCaches finds its way onto my workbench the next time.
Until then I would say you should be fine to run the card without the caps if there are no other signs of damage.
EDIT: just saw the picture in the other thread, you might want to check the traces right next to the "K10" silkscreen. They look a bit strange on the photo, might as well just be some dirt but I can't really tell.
Edited by Bolle
Share this post
Link to post
Yes, I had the capa tested and it is as you say.
I just noticed the wired traces near K10, they could be broken but there is some “goo” on the black spot. Could be from the factory...
Share this post
Link to post
"A propos" KTKM, my P33 33mhz works perfectly in my SE/30 along w/ a cloned TwinSpark adaptor and a Farallon ethernet (RJ45) card only when the Power Central control panel is uninstalled.
Power gain is significant and TattleTech displays clearly the 33mhz CPU and FPU.
W/ Power Central installed, the system freezes at bootup.
Edited by Ralphieboy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
