Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10095 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3972
      posts
    2. Conquests
      39502
      posts
    3. Trading Post
      52976
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1486
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      493
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45855
      posts
    2. Mac II, Quadra & Centris
      13028
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7953
      posts
    4. 68k PowerBook
      9848
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2669
      posts
    2. PCI Power Mac & Performa
      5881
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13720
      posts
    4. PPC PowerBook & iBook
      8965
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7386
      posts
    2. Newton
      1066
      posts
    3. Software
      17461
      posts
    4. Hacks & Development
      18528
      posts
    5. Peripherals
      14519
      posts
  • Posts
    • So it boots off an X/Profile on a 2/5. HELLO.APP works, but 1ST_WORD.APP causes a complete system hang when trying to create a new document. Make sure to have a floppy disk inserted if you try to access the drive, otherwise it will crash the system with Lisa Error 47.   Also: don't forget to copy ASSIGN.SYS and LISA25.SYS to the hard drive when doing your file copies.
    • Having two Macs is never a bad thing. They're very comparable, as everyone has said. You may want to pick up a pair of LocalTalk or PhoneNet boxes and play around with networking them.   In terms of the Plus vs SE debate, don't forget the Classic is also comparable. Its advantages are RAM expansion being easier (as long as you have the card) since no Classic board used resistors and its screen being easier to adjust without taking the case off. The ROM disk is also a nice perk. However, the Classic is notorious for capacitor problems and has design limitations based on it being the cost-cutting model of the SE (no second floppy capability, only one ADB port, no expansion slot, weaker power supply). The SE wins overall between these three machines.
    • Agreed; the Plus is lovely as an æsthetic object, but the SE is a markedly better computer for normal use and, as noted above, not really less compatible.  I have a Plus out all the time with an HD20, but honestly, primarily as ... almost like a small sculpture, rather than for regular use.
    • Don't jump ahead just yet. There are a few things you could try first. If you have a RAM expansion card, verify it's in the correct connector (J11) - happens to everyone. You could try starting both with and then without the expansion card. After that, I'd examine the onboard RAM near where you were recapping to see if there is any residue or damage. I don't know offhand what banks are where, but start with a visual inspection.   Also make sure to do a power manager reset if haven't been.
    • ... it would help if I actually attached the files, wouldn't it. gemdos11-apps.dc gemdos11-boot.dc
