Jump to content
Sign in to follow this
MJ313
CF in Takky?
Recommended Posts
Takky interests me... 3.3v regulator does not :) Some boards, like the 6500, apparently you can get away with not using a 3.3v regulator if you don't push the board too much and forego PCI. 6400 boards seem to require the regulator regardless and I *think* this is due to power draw?
I am wondering if using a CF to IDE adapter would reduce power draw enough to allow 6400 to work without a 3.3v regulator?
Also, in 2017, are there better (easier) options for use as a secondary power supply?
I don't have a takky and this is more just an entertaining notion at the moment.
Share this post
Link to post
Share on other sites
On 4/21/2017 at 5:45 PM, MJ313 said:
Works perfectly. Thanks man!
Would you be good enough to update the links to the pictures please?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
