Jump to content
Sign in to follow this
beachycove
Quad G5 LCS experiment
Recommended Posts
So the time came to service the LCS on my G5 Quad, which involves flushing the radiator and hoses, renewing the thermal paste, etc. It's a pain in the gluteus maximus.
One of the usual problems with these machines is that sediments in the coolant clog the microchannels and associated components in the cooling block. I duly cleaned mine up, refilled the system, and started 'er up — only to have a large temperature gap between the two CPUs. So I figured I'd take the offending processor apart and see what was the matter.
On taking the thing apart, I discovered that the microchannels were starting to plug up with sediments again, with the machine having run for no more than 45 mins. The radiator must be dirtier than I had thought, though I used a radiator cleaner and had taken the best part of a day to do the job right first time around.... I then had a brainwave.
"If the problem is the microchannels, what if the microchannels were removed?" thought I. I figured that if I was going to have to strip the thing apart again, I might as well do a little experimenting, and see if I could prove something to myself. So, I removed the internals in the LCS waterblock, which is a soft (silicon?) black pad, a hard plastic/ silicon microchannel insert, and a pink foam washer. I've attached a pic of them removed (they are now stored in a bottle of distilled water).
I then reassembled the LCS without these internal components, i.e., with the hole where they went empty as in another attached pic.
I then reassembed the lot, booted, and what do you know? The thing works perfectly, at the moment at any rate. I've attached a screenshot of the CPU temperatures over a five or six hour period today under varied levels of activity.
Iam not sure I will leave it this way, but at the moment, the machine appears to be working as well as it ever did. Temperatures are about normal for a G5 Quad (Processor is set on Automatic). While posting, I took a shot of the current temps in numbers for posterity.
Neat, wot?
Unfortunately, it fails thermal calibration in ASD2.6.3, which reports that the readings are out of specification. So I have to operate under my previous settings.
Edited by beachycove
Share this post
Link to post
Share on other sites
Those microchannels are for better heat transfer (faster velocity, better stream mixing). If you have issues with fouling clean the radiators and maybe put a filter inline (will need maintenance just like everything else).
Share this post
Link to post
Yes, I thought about a filter back when I first overhauled the system 4-5 years ago, but never installed one first nor last. There were actually two tiny pipe-sized stock filters in the plumbing, as shipped from the factory, but I removed those back then because they were plugged pretty solid, and they were completely inaccessible, down by the pump or some such thing. I thought that an occasional flush, etc., would suffice. Unfortunately, that's not the case.
As I've got it working now better than it has for a year or more, I will likely leave it as is for a while and see what happens. But if I do go back to the OEM microchannels, I will clearly need to deal with the sediment problem. Whatever were done, I think it would be done via an extension into the upper bay, so as to make servicing less of a hassle. A filter is one option; another is one of those little acrylic fluid chambers, in which sediments could theoretically be expected to collect in the base...so they could then essentially be vacuumed out with a syringe or drained away.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
