Jump to content
SuperRey
Correct jumper settings for SCSI HDD on an Apple LC 475
Recommended Posts
Hello,
I have been struggling with the jumper configuration for a 50-pin SCSI HDD.
The model is IBM DSAS-3540.
Of course, id, was set to 0, and internal terminator was enabled but it was not detected.
I have 3 more settings I can change with the jumpers:
  • Disable auto spin up
  • Disable unit attention
  • Disable TI negotiation
I started disabling the TI negotiation, and now it seems to work.
The question is, should I disable the other two?
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
