Jump to content
Any thoughts on this....it arrived!!!
  • Please log in to reply
105 replies to this topic
#21 bibilit
bibilit
  • 68000
  • LocationParis area -FRANCE-
Posted 22 December 2016 - 07:48 PM
some information about the Videx card
www.apple-iigs.info/doc/fichiers/videoterm.pdf‎
Edited by bibilit, 22 December 2016 - 07:48 PM.
Macintosh Classic and II ,CC, SE, SE/30,IIsi 25mhz(RasterOps video),Q 700,LC, LC III,LC475, PBook Wallstreet/Bronze/5300cs/1400c/100/Tibook Imac G3 slot-in, Bondi and G4 / PMac G4 sawtooth, QS, MDD, Yikes!, Cube, Imac Core 2 Duo, Ibook G3 (white/clam) G4 + Newton 120, eMate 300,Quicktake 150,  PowerCD
#22 techknight
techknight
  • 68LC040
Posted 22 December 2016 - 08:57 PM
Either way, someone definitely went through the trouble of pimping out an Apple II.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, ibook g3x2, Lombard, 160, 165, 180, 180c Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, SE, SE/30, 512k, plus, LCIII, iMac G4, iMac intel, 6400/225
#23 Gorgonops
Gorgonops
  • Moderators
Posted 22 December 2016 - 09:30 PM
It would be interesting to know the *why* behind hacking together such a monstrosity, and whether it was truly a one-off for personal use or is something that was "professionally" repackaged and sold as some sort of embedded/turnkey solution. I find it noteworthy that it was fitted with a CP/M card; that's more evidence that it was built for a business application. The question would be, of course, why you'd go through the trouble of stuffing an Apple II+80 column board+CP/M card+hard disk into a case that probably could have been ordered off the shelf with a Z-80-based computer in it already.
#24 techknight
techknight
  • 68LC040
Posted 22 December 2016 - 11:20 PM
I havent ordered the replacement parts yet on my crystal ball. Once I do, maybe we can find out ;-)
#25 rsolberg
rsolberg
  • 6502
  • LocationVancouver Island, Canada
Posted 22 December 2016 - 11:44 PM
While the fumes and smoke from soldering certainly aren't healthy in significant exposures, I expect your vision change may have more to do with spending a lot of time focused close up on fine work. As we age, the ocular muscles become less elastic, so it becomes more difficult to keep things aligned from near to far. I have strabismus which is a misalignment and have found it's become significantly worse in the last few years.
68000: Mac SE Superdrive, 68040: Mac Colour Classic "Mystic" w/VGA mod
#26 just.in.time
just.in.time
  • 6502
Posted 23 December 2016 - 01:32 AM
...This is most of my collection to date...
All that ancient white plastic sitting in the direct sun light is killing me.  You can almost see it turning yellow in an instant  :O
#27 falen5
falen5
  • 6502
Posted 23 December 2016 - 01:36 AM
That maybey it rsolberg. Spent hours looking for broken traces etc etc......one day eyes got blurry, gave them a rub..no good...........getting worse all the time......dam old age too
Got this machine apart - took 3 or 4 hours. anyway here are the goods
Edited by falen5, 23 December 2016 - 01:45 AM.
#28 falen5
falen5
  • 6502
Posted 23 December 2016 - 01:39 AM
Heres what i figured out so far with the power supply's......all 4 of them i rekon
#29 ScutBoy
ScutBoy
  • 6502
  • LocationNorthfield, MN
Posted 23 December 2016 - 02:06 AM
Props to whoever hacked this thing together, but the words that keep coming into my head are
FIRE HAZARD!
#30 falen5
falen5
  • 6502
Posted 23 December 2016 - 02:15 AM
I dont understand the large memory board for the hard drive. Was this the norm back then to use a hard drive with an apple ii. Looking at scsi boards on ebay  for apple ii's i gather you just plug the drive straight into the scsi board and your away. ScutBoy... taking it apart, I was thinking whoever built and used this thing was a brave person.........Explosion Hazard is what i was thinking
just noticed... the II power supply looks to be riveted together.......how do you open them .......drill?
Edited by falen5, 23 December 2016 - 02:17 AM.
#31 Gorgonops
Gorgonops
  • Moderators
Posted 23 December 2016 - 03:03 AM
Why do you think that's a memory board? Your picture isn't quite high res enough for me to read every chip marking, but to me it appears both the main and daughter boards are just stuffed full of '74 series logic
#32 falen5
falen5
  • 6502
Posted 23 December 2016 - 01:34 PM
Hey Gorgonops - Im only going by what someone said earlier on here  - someone said memory board , someone else said 'MFM to' (just checked, that was you- haha) - i have no idea gorgonops. Im calling in the 'X' board.
I did a bit googeing and the motherboard is a "RFI board 820-0044-01/C/D silkscreened visibly on the board, 8111 to
end of production, no memory select blocks, used maybe on very late
Apple II and obviously IIplus."        - so dont know if it is a II or a II plus. but ill give it a good cleanup and test it later
Im looking at the power system - today going to take it all out and lay it all out on the floor. I think the 2 round transformers, that  are going into those large blue capacitors, and then into two rectifiers?( they are the 2 on the big heat sink) - from there they feed power to the hard drive and the X board. It becomes less scary as you break it down bit by bit
will have a good look at it when its all laid out on the floor and try powering some of it up today bit by bit. - just the power system - motherboard, drives, 'x' board all have to be cleaned and checked. Will test the motherboard and cards using one my II e's later
I really want to see if there is any possibility of restoring the whole thing.
That hard drive is the mystery - if it can be revived it would be great to see what is on it - i have never had a drive like that before - looks clean, no sign of corrision
all i can do is check the connections of the power system, look for bulging caps, shorts, bad connections -  if they look good  plug them in and stand ready with fire extinguisher
#33 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
  • LocationBermuda Triangle, NC, USA
Posted 23 December 2016 - 02:38 PM
What's the diagonal of the CRT? Sourcing a TV CRT/Power Board replacement for that might clean up your mess considerably and you wouldn't need to test high voltage connections in your restoration process. Having one constant, known good reference point that you can hook up in its enclosure would make reconstruction of the rest a lot less hazardous.
< /lazy-cheater mode >
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
#34 james_w
james_w
  • 6502
  • LocationLondon, UK
Posted 23 December 2016 - 02:40 PM
i dont know what the goo is on the motherboard is - but it looks like it came from above the machine, landed on the drive bay cover and worked its way down. Does not seem to be corrosive . No signs of rust or corrosion of the electronics ... SO FAR...... there are lumps of rust laying about in there... cant see where from...from above pics there is some rust/corosion on the pins in the slots but they look intact. Just got home. Will start stripping this thing in a while - hope to have it completely disassembled tonight. will share what i find.
This is most of my collection to date - fixed / recapped most of them  bar 3 or 4 se/30's from the maxell bomb syndrome, and another 2 or 3 plus's that i cant get working. Question.... i had 20/20 vision when i started doing this madness about 3 years ago...........now i have very bad short sightness............to this day i still believe it was the fumes and smoke from soldering.........just wondering if anyone else had similar experience.
Serious kudos to you for all the effort! I've probably only recapped 5-10 (lost count) of my 50 or so Macs... seriously impressed! :D
💾 👉 hypertalking.com
Lisa 2/10, Original 128k (upgraded to 512k), 512k, 512k (upgraded to Plus) x2, SE (FDHD), SE (2 x 800k), SE (800k 20SC) x2, SE/30 x2, Classic x2, Colour Classic (Mystic), IIsi, IIci, IIfx x2, LC 450, Centris 650, Quadra 605, Quadra 660AV, Quadra 700 x2, Quadra 950, Cube G4, Portable, Portable (Backlit), PB 100 x2, PB 165, PB 170, Duo 230, Duo 280c, Duo 2300c, PB 2400, PB 1400c, PB G3, PB G4 Titanium, iBook, MP 130, MP 2000 (upgraded), MP 2100, eMate 300 👽 Dynamac EL 1701, Outbound Laptop 125 x2, Outbound Notebook 2000 Passed on to other collectors: Lisa 2/5, SE/30, Portable, PB 180, Duo 280c
#35 waynestewart
waynestewart
  • 6502
  • LocationVancouver BC
Posted 23 December 2016 - 03:04 PM
It’s got II Plus ROMs.
The dates I see on the chips seem to indicate 1982 as a likely production time. Which would means it predated ProDOS. It’d be interesting to get the hard drive going.  I’m wondering if it’ll be CP/M.
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
#36 falen5
falen5
  • 6502
Posted 23 December 2016 - 03:09 PM
hey trash80- cant find a measure tape so looked at the crt - says 12'. I hear you on the power supply situation. I am not looking forward to powering any of it up. Even if nothing blows and i get steady voltage it will not be under load. If and when I plug in the hard drive and board X the load might blow the hell out of the caps, transformer and blow the drive up etc etc. saying that The look of the thing as it was origionally hacked together  has me in a daze. Would be sooo cool to see this thing running. If the volatge is 12volt i could plug in a spare 12volt drive I have to test it under load. Have not had a good look at the rated outputs that are written on the transformers - as for the analog board there is so much stuff hacked onto it with switches front and back that has me is a daze as well.
Is there a danger in powering up an analog board NOT connected to a crt? anode cap just lying there? would that in itself blow something ?
Im all for restoring stuff, not blowing it up, and with this beast I am really stuck between saftey and origionality. I do not have the knowledge for this. Top priority is not to blow it up
hi James ..... this is a mental sickness!!!.......I was sure I had made a full recovery for the last year and  quarenteed the sickness back into the attic. 2 weeks ago i got an apple ii, the sickness led to this discovery. In 2 days it has taken over the kitchen and is now rapidly spreading throughout the house. Thank god herself is away for christmas. I have 5 days to get this outbreak under control before her return!!. Ah sure feck it, it could be worse i guess. Now , lets start plugging this thing into the mains
howya wanystewart - that z-card seems to indicate cpm allright - will be a miracle if the drive is still working - there is rust on the swingarm motor - will be a slow step by step process
Edited by falen5, 23 December 2016 - 03:17 PM.
#37 waynestewart
waynestewart
  • 6502
Posted 23 December 2016 - 03:25 PM
Hard drives are pretty much airtight so there is room for hope. This week I tried out a 5 and a 10mb Profile hard drive. Both worked
#38 Carboy7
Carboy7
  • 6502
  • LocationDurham, North Carolina, USA
Posted 23 December 2016 - 03:31 PM
Ahh! You better hurry up and get it working!
No pressure ;)
I've been dormant for a long time. Blackbird,145B,PDQ,iBook,iMacG3,(2)iLamp,LCII,IIsi,PMG4,SPARCstation 5
#39 Trash80toHP_Mini
Trash80toHP_Mini
    NIGHT STALKER
  • 68040
Posted 23 December 2016 - 04:17 PM
hey trash80- cant find a measure tape so looked at the crt - says 12'. I hear you on the power supply situation. I am not looking forward to powering any of it up.thing into the mains.
Excellent, I was guessing it'd be a Lisa-like 12" CRT. That opens up some very interesting tangential hacking opportunities if and when.
Meanwhile, you can use any size uber-cheap TV set or any NTSC input LCD TV you might have on hand for your testing. ;)
Edited by Trash80toHP_Mini, 23 December 2016 - 04:22 PM.
jt [8]
#40 Gorgonops
Gorgonops
  • Moderators
Posted 23 December 2016 - 04:48 PM
I guarantee it's a hard drive controller. That board assembly was connected to the hard drive via two cables, a 34 pin one and a skinner 20 pin one, right? That is ST-506 cabling:
https://en.m.wikipedia.org/wiki/ST-506
Standard for "inexpensive" MFM and RLL hard disks from the late 1970's up through the end of the 1980's. This is an extremely "dumb" interface, not much more sophisticated than that for floppy drives, and has extremely strict requirements/limitations on cable length, controller latency, etc. Therefore it was very common when these drives were used on slow computers or in external boxes to use a controller board directly attached to the drive that handled the fast, dumb communication there and presented a more forgiving and simpler to interface to connector on the other side. That is what you have there. A common standard for the other side was called "SASI", which was an 8-bit parallel interface similar to SCSI, and I suspect that is what the host adapter card plugged into your motherboard supports.
Crack open an old enough external SCSI case and you'll often find a similar board doing SCSI-to-RLL or SCSI-to-EDSI (another obsolete interface standard) conversion in front of the actual drive.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
