Jump to content
Sign in to follow this
Unknown_K
Unknown_K's latest conquests.
Recommended Posts
Figured I might as well start a topic for conquests.
Latest 3 machines are laptops:
iBook G3 14" 600mhz, video seems kind of flacky, HD needed replaced, has Max RAM, mouse plug needed re attached.
iBook G4 14" 1.33Ghz, just needed a reformat and some cleaning.
iBook G4 14" 1.42Ghz. Needed some cleaning, OS reinstall, and reseating the HD (worked then didn't, screw holding the drive in were loose, a pain to get to).
These are the first of the 14" iBooks in my collection, have a bunch of 12" models but these are nicer. Have a couple 1GB DIMMs coming for the G4's to max them out. The 60GB drives are good enough for my needs so they stay.
Funny how a little Windex and a magic eraser will cleans these things up like new.
Share this post
Link to post
Share on other sites
Yeah, but I'm not sure if it's the card or the socket, and mine was damaged by the PO in a take apart, so I really don't want to pull it apart again. Frustrating as I stuck an mSATA card inside too.
Edited by TheWhiteFalcon
Share this post
Link to post
I am getting faster at taking apart ibooks, but I still hate doing it. A 15/17" Powerbook is much easier to work on.
Do you have any after market batteries?
Share this post
Link to post
I have a bunch of 3rd party batteries for my Thinkpads, some are good and some kinda suck depending on age.
Thinking of getting one for the 14" g4's, I have a new one for my 15" Powerbook G4s but it doesn't seem to last more then 1.5hrs. One of my OEM 12" iBook batteries has some life in it as well, same for a Ti G4.
Share this post
Link to post
I get about 2 hours from the MBP, but I notice that in System Profiler it reports it as having half the capacity it's rated for. The MBA varies on how hard I push it, but if I'm just doing word processing I can get six or so hours out of it (original was only rated for 5 hours 'wireless web', back when Apple's testing was...optimistic), or three under 'hard' use.
Share this post
Link to post
When I'm running Pro Tools on my 2012 MBP (i7 2.6 GHz with 16 GB RAM), I'm lucky if I can get 45 minutes to an hour on a full charge, and the machine feels like it's going to burst into flames ( :o).
It's fairly average when I'm not using PT, though: I can get 2 or 3 hours when doing word processing or web browsing, and maybe a bit more if I turn the screen brightness down and disconnect my external hard drive and phone (if I let it idle a bunch with the screen off, I can get 4-5 hours out of it sometimes).
c
Edited by CC_333
Share this post
Link to post
Thing I find with the G3 600MHz iBook is that the only OS worth running on it is OS 9. App support for 10.3.9 is quite sub-par, so 10.4.11 is about the only version of OS X I like to use in the G3/G4 generation. It runs pretty abysmally on the iBook G3, and TenFourFox takes ages to do anything. BUT, all that said, OS 9 runs splendidly on the iBook and, as far as I remember, the first 12" G3 iBook (white) running at 600MHz actually shipped with OS 9 rather than a flavour of OS X, but my memory might be a bit fuzzy on that. I miss my Ti 1GHz, which I ruined ages ago. That was probably the best laptop for OS 9/10.4. Shame about its relatively crack-prone case, though. Anyway, great little haul there. =)
Share this post
Link to post
Today I got in an empty box. It's the OEM box for a Powerbook G4 15" A1138 highrez figured what the heck it was free for shipping and I own a mint unit of that model.
Also got in 4 iBook 12" screen assemblies plus an ugly looking iBook G4 12" 1.33ghz in parts. Needed a screen for the 800mhz model I have with a cracked screen (has been fixed today). Not sure what to do with the parts machine, it has seen better days.
Share this post
Link to post
Won an iBook 12" battery and got it in today.
Hi Capacity model B-5901, charged up to 4237 mAh cycle count of one (new opened box).
Not too bad for $6.78 shipped. Same seller had a NIB shrinkwrapped 3Dlabs Wildcat II 5000 CAD card for the same price shipped.
Share this post
Link to post
For some reason I purchased a Powerbook 1400cs and it came in today. Has one of those clear plastic top covers, CPU 603-117, 700MB HD, floppy drive, and I think  12MB of RAM. Previous owner has OS 8 on it, I was thinking something older like 7.6.1?
Share this post
Link to post
Did you buy it while you were asleep?
Anyway, I'd say 7.6.1 will get you most of what 8 has to offer with less of the bloat (you'll get the older, pre-Platinum UI, which is probably a bit lighter on RAM, I'd think).
c
Share this post
Link to post
The basic model 12MB RAM, 117 CPU no cache, 750MB HD, floppy drive, clear plastic removable cover. I cleaned it till it looked new, tested it, and put it on one of my laptop shelves in the basement. Normally I would look for the faster CPU upgrade, more RAM, find a CDROM drive, and put in a larger HD (I have stacks of IDE laptop drives) but for now I am not too motivated.
One odd thing was when I plugged in the power brick the unit started on it own. When I shut it down it stayed shut down like I should. Wonder if the start key is stuck or it just does that.
Share this post
Link to post
Really? Plug in the brick and the computer immediately starts up is normal? My 3400 didn't do that. The only machine I had do that had damage from a leaked battery.
Share this post
Link to post
I've got a crap ton of NuBus Architecture PPC PBs and Duos and if one of them failed to boot up normally when I plugged in the power adapter I'd be surprised enough to think something was wrong with it.
IIRC, the /117 can't use the later processor boards, only a G3 upgrade. If you found any 1400 with a stress crack free lid (hinge plate area) it's a big win for you.
Edited by Trash80toHP_Mini
Share this post
Link to post
Snagged a MacBook 4,1 (2GB RAM, 160GB Apple HD). Came with a Silm power adapter (with USB plug). Battery is charging, it is an aftermarket SCDA battery with 5 cycle count.
Installing Snow Leapard on the HD (must not have had a OS when I got it).
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
