Jump to content
bibilit
Classic II Analog Board / no output
Recommended Posts
I am trying to fix a Classic II Analog Board, the primary side is ok and the fuse also, but i have no output on the secondary side (0 volt)
Removing and replacing capacitors didn't solve anything, probably a faulty component, but don't know where to look next.
Share this post
Link to post
Share on other sites
Not fixed this unit yet, but had another one to repair, blowing fuses all the time.
My first bet was that the bridge rectifier was bad, and at first check - and + where shorted, but on removal all was ok.
Turned my attention to surrounding components, in the end The Mosfet on QP2 was shorted (IRFBC40).... a swap, some new caps on the Logic and Analog board and i have a nice working unit
Already been talked about here, so this Mosfet has a tendency to go bad.
Edited by bibilit
Share this post
Link to post
Ok thanks is this the CNY17G-3 ?
For my information, is this component acting as a switch ?
Also, do you know the difference between the CNY17-3 and the G variant ? (as the first can be found easily)
Thanks again.
Share this post
Link to post
No luck here.
I saved one board yesterday, but replacing the Optocoupler in the others didn't solved the issue.
Any idea where to look next ?
Edited by bibilit
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
