Jump to content
techknight
Color Classic VGA Mod. the CORRECT way
Recommended Posts
2 hours ago, techknight said:
the 550 analog board wont directly fit in the CC. its too wide and needs modded.
Are you talking about the physical modification because it’s too wide or additional modifications to the actual circuitry? I get that it is too wide.
Share this post
Link to post
Share on other sites
14 hours ago, Macdrone said:
i meant the motherboard.  The analog board must be cut short to fit in place.
What changes need to be done to the motherboard? Sorry if I'm getting confused. I know I have to cut down the AB from the 550 to fit in the smaller CC case.
On a side note does anyone have access to the schematics for the CC and Macintosh TV logic boards? I recapped the Mac TV board and everything was working correctly. Now it won't mount the internal SCSI drive. If I pop the CC Logic Board in it boots fine.
Share this post
Link to post
the motherboards need no change.  the 550 and cc motherboards are interchangeable as the 550 motherboard is also the color classic II motherboard.  Macintosh TV motherboards are weird, did you wash the whole board ?  When I had my macintosh TV the motherboard needed alot of cleaning.
Share this post
Link to post
I used  I saprobic alcohol 99% to clean the board and when I put it into my color classic it had a distorted video but it and boot it now I get this started video still but no hard drive is found. I’ve heard people running it through the dishwasher
Share this post
Link to post
Definitely wash the board. One of my SE/30s just  showed horizontal stripes even after cleaning with alcohol, but once I washed it, it booted up perfect with no issues.
Share this post
Link to post
Okay. Will do that! Will jetdry cause an issue? I know you do it without detergent
Share this post
Link to post
jet dry will cause no issue as its made to run off clean also.  I dont use but a drop of detergent and wash it alone when I do it on bottom rack.  Need as much heat and pressure and vertical to get that goo freed up and run off.
Share this post
Link to post
Okay I wash the boards in the dishwasher. Still no boot sound on the CC logic board and the Macintosh TV Board still doesn’t see the hard drive. Anyone know where I can get schematics?
Share this post
Link to post
Bump on Schematics?
Share this post
Link to post
Is there a ‘master’ list of components and steps for performing this upgrade?
I’ve found several ‘guides’ (including this one) which all refer to each other, and have missing or contradictory component lists. I’m looking for something like:
1. Get these tools
2. Source these components
3. Clean the board with this solvent
4. Look for these defects (or trouble spots)
5. Follow these steps
I’m attempting to repair a color classic and I don’t have any spare boards if something goes wrong. I’d normally be glad to go through decades of comments on these threads, but I’m in a bit of a time crunch and this clearly has been successful many hundreds of times.
Does such a thing exist?
Share this post
Link to post
D.....
Here is a colletion of all the links you need and even old ones missing from the itnernet:
https://powercc.org/
You can find the most detailed upgrade descriptions to your hardware at the above site as well.
mraroid
Share this post
Link to post
Apparently there were slight variations of this analog board and it wont work for all. Just got a PM from a guy running a Rev C I think it is, and its got a weird pincussion issue.
But I cant verify how it was done though. Just an FYI.
Share this post
Link to post
1. Get these tools
I have repaired 3 CC Logic Boards, 1 Macintosh TV LB, and 1 LC 520 & 1 Performa 550 LB.
I used clippers to clip the old caps off the boards. Clipping at the center of the Cap. I then used a flathead screwdriver to carefully remove the bottom portion of the caps. I left the metal poz & neg leads/posts left from the old cap still soldiered to the board. (removing them when I was ready to put on the new Caps)  Then ran them through the dishwasher as outlined earlier. I shook the boards to get as much excess water off (even though I had the dry cycle on) and put them in a dish drying rack with a fan blowing directly on them. I started with the Ports facing down to ensure any water trapped in the ports would drain out first. I rotated them every 6 hours. After they had a good 2 days of a fan blowing on them, I was sure that they were dry. Then I soildered on the new Cap's. It was easiest to put a bead of solider on the poz and neg terminals of the new caps first. Next I started to remove the old Cap leads/posts using resin were needed. (BE VERY CAREFUL - you can easily lift the metal pad off the logic board if you're not careful. Then you'd have to do a trace repair; which can be a bitch)  Finally I got the new Caps on and popped the new batteries in. All boards worked. The one that lost the startup chime still didn't make sound though the internal speaker. But external speakers work fine. (had to get Stereo to Mono adapter for best sound.)
I'd like to point out, that the Macintosh Performa or LC 520 & 550 logic boards work in the CC without any changes. Essential the LB from the 550's is the same as the Color Classic II @ 33MHz. The 520's are 25MHz, which is still a hell of a lot better than the underpowered 16MHz of the original CC.
The thing that took to longest for me was sourcing the Caps as I wanted to use SMD/SMT Tantalum Chip Capacitors. They were only shipping from china off Amazon. I purchased them ahead of time so I'd have them right after the boards were done drying.
Edited by Cubbie036
Share this post
Link to post
The Macintosh TV issue was that, though I fit in the CC, the Analog Video board was not powerful enough to provide power to everything. I popped it into a the Performa 550 and booted up perfectly.
Share this post
Link to post
Welp, I'm gonna take the plunge. I just ordered a handful of 216K resistors from "Surplus Sales of Nebraska," as they were pretty much the only place I could find 'em. They claim to be 5-watt, 1%. I'll definitely test 'em and post results when they arrive. Here's a link if anyone else is having trouble tracking some of these down (very top item, assuming you see the same list I did):
http://www.surplussales.com/Resistors/MetalFilm/MF216k-332k.html
I've got two CC2s and one Performa 275--that one's a bit rare and I'm gonna leave it alone for a bit. I'll probably start with the more beat-up of the CC2s I've got. I've got a few boards for Mystic '040 upgrades and will try to keep images and progress posted here.
Long-term project is an attempt at cramming a DOS-compatible board from a Performa 630 into a Mystic '040. I know it's missing the video port on the motherboard, but... I feel like there's a way this can be done without actually doing a full Takky mod. Everything else is there... it just feels so possible. Maybe someone has already done it? I couldn't find anything online. I've already got a Performa 630 DOS-compatible motherboard ready (purchased on eBay a couple of years ago when I first thought about giving this a try). Feels like a good project to take on.
Share this post
Link to post
The IDE-based boards like the 630 will not swap into a CC variant (or indeed any other AIO models except a 58x). For that, you'll need to do the Takky mod. While you can basically run the Takky mod off of the stock CC analog board, it's not recommended: the 68040 draws more power than the 68030, which is stressful enough; adding a high-res mod and expansion cards (let alone a DOS card) could cause stability and longevity concerns. Usually major mods like that use an analog board from a 5xx because they're already set to run high-res and can put out a bit more power. They need to be physically cut down, though, because they're too wide to fit in a CC chassis as-is. It's major surgery but props if you can do it.
Does the 630 DOS card fit in a 575 logic board? That may be interesting if it does. Also it would swap directly into a CC without a Takky mod, though you'd still need to do something about the resolution (either high-res mod or ResEdit hack). I'd still be concerned about the power draw of the DOS card; the 486 wasn't known to be a low-power chip.
Share this post
Link to post
Ah, but the 630 DOS card is a really bizarre creature, much different than most of Apple's other forays into the territory; it plugs directly into the '040 socket. The '040 and the 486 reside on the same daughterboard, with additional connectors plugging into the PDS (interestingly, the PDS connection does not include the extended pins) and the small, odd video port near the motherboard's main connection pins. This small port is the only one the 575 board is missing, and this is the reason why I think I might be able to make the DOS card work.
Power draw is definitely a concern.
I'm not really big on the Takky mods, 'cause I don't wanna do that much work and I cringe at the thought of cutting up a CC chassis. I avoided the screen res mod simply because I didn't want to cut a trace! I'm probably just a weirdo. That's the reason, though, that I'd wanted to try the 630 DOS surgery on an earlier '040 board, rather than just do the full Takky mod.
Here's a pic of the 630 board (not mine; I found this online, but I'll get some close-up pics up tomorrow if I've got time). You can see the '040 next to the pins where the actual CPU socket is located. The small video connector is on the right in the foreground, blue on the daughtercard, brown on the motherboard. Some Quadras (not the DOS compatibles) seemed to use this port as a video-out port (a ribbon cable runs from it directly to the video-out port at the back of the chassis).
Share this post
Link to post
I don't like major mods to something unless I have multiples or one is in bad shape/dead anyway. I bought a CC II where it turns out someone had done an improper high-res mod involving the trace cut/transformer jumper technique. I finished the mod but apparently I need to try another capacitor value or two because my screen is still too wide. Of course, being a CC II, it has a later analog board so the upgrade components and locations listed here don't align properly.
The 63x's is the only DOS card that connects in that manner, and as such is the only one I really wanted to find (I got a Performa 640 DOS). Interestingly, the 68040-based compact Mac PowerPC upgrade card connects in the same way, though I sincerely doubt you could run them concurrently.
The connector on the logic board is supposed to be for external video out, but it may be software-switchable to do the DOS card video input instead (I'm not 100% sure how these things work; it's not terribly detailed in the Dev Note). If so, you can probably modify an external video kit so that it permanently displays your DOS environment on a separate monitor in the same way that the other DOS cards do.
Of course this all assumes that the 575 and 6xx logic boards have the same layout; the DOS card is a very tight fit and a small variation in component placement could cause problems.
Share this post
Link to post
Tried to do this mod on a revision D board and got smoke. Oops! I went with the 640x480 posting at Powercc.org.
Here is a list of the parts mentioned to replace and what the Rev D board has:
CL9 and CL10 - 3.3uF - Changed to 2.2uF and 1.8uF respectively.
DL21 and DL22 - Changed to single 18V Zener at DL21(doesn't really matter as they are in parallel and the factory diodes are also 18V).
RP6 - 5.6K - I left this alone as the site says 4.52 to 5.11 and I found a different, higher, value.
RP8 - 15K - 33K
RF14 - 236K - 216K
RP23 - Unpopulated in Rev D - This is because a charge pump from the standby/crt supply feeds this circuit so I left it unpopulated since it only affects the logic supply.
RL54 - 18R instead of 33R - Changed to 15R.
RP61 - Already populated with 7.5K.
RL62 - 47R - Changed to 100R.
RL70 - 33K - 22K.
J104 - Jumper - 10R.
Sense line change is a bit more complicated. Revision D does away with J78 and J79 and there is a diode in that area. To make pin 20 connect as though it has J79 bridged you have to cut a trace from 20 to GND going towards the connector and run a jumper from 20 to 3.
I have not figured out where the smoke came from but I will borrow the FLIR from work and see if I can find it. Nothing looked obvious though as I turned it off the instant I saw it. When I turned the computer on the CRT breifly got HV and then lost it resulting in the normal static crackle. Screen stayed off and blank while the computer itself proceeded to boot.
Edited by dkjones96
Share this post
Link to post
So, I don't know if I was just imagining smoke or what but there wasn't anything overheated or burnt when I very thoroughly looked over the board. I did have a wiring error on my part but it was signal level and what caused me to have no screen before.
It looks like I need to up the voltage a bit. I tried adding C26 from 1nF up to 5nF and all it appears to do is make the edges at the top and bottom extend to beyond what the horizontal deflection circuit can handle in the middle resulting in bad bowing and it makes the screen dimmer. It isn't a terrible aspect ratio, it is currently at 1.15 and I would like 1.33(4:3) It could be corrected by shrinking the vertical height but I would like it to take up more of the screen.
I took a thermal camera image of the AB after it ran for a bit but forgot to bring it for posting this. Hottest I found was 165F at the big guy near RF19 and second highest was the 7.5K at RP61.
Share this post
Link to post
Alright, RP6 needs changed out, you can only get 72V max with it as-is. Swap RP6 to a 752(7.5K) 1206 resistor and you are in business. Looks beautiful! I had only an 822 1206 available but it requires PP1 to be turned down all the way to get 84V.
Only problem left is RF11 which runs over 300F as-is and when it's that hot you can't reboot or you'll lose sync and you have to shut down until the resistor cools and it seems to work fine again.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
