Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9930 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39243
      posts
    3. Trading Post
      52360
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1484
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45166
      posts
    2. Mac II, Quadra & Centris
      12869
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7887
      posts
    4. 68k PowerBook
      9730
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13678
      posts
    4. PPC PowerBook & iBook
      8950
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7307
      posts
    2. Newton
      1063
      posts
    3. Software
      17342
      posts
    4. Hacks & Development
      18339
      posts
    5. Peripherals
      14411
      posts
  • Posts
    • Yes a blasting cabinet is great, but hard to see through after a couple of minutes, it's more a hit and miss game.   Yes again, touching the sandblasted metal with your fingers is not a good idea, the damp skin is to be avoided in bare metal.   I will go for a grey or metal finish, but just my point of view.   Concerning the Retrobrite, i have had better results boiling water first, and mixing it with Vanish on a second time (don't use peroxide anymore, Vanish is more easy to use and do more or less the same trick)
    • I recently ordered some replacement gears from here: https://www.shapeways.com/product/27DNUVPJA/replacement-floppy-drive-gear-for-macintosh-comput   $8 for 12 parts + shipping   The design is opensource, you can find the 3d files here:  https://www.thingiverse.com/thing:4167139   I have quite a few drives I'm replacing the gears in so I'll post my experiences here.   Replaced my first drive - an 800k external that was not ejecting. You can see the in the first picture the state of the old gear, it denigrates to the touch.   The fit is good, you can see the teeth line up well.   The video shows the first few ejects. Note the springs for the top were not attached when I took the video. Also the drive has some noise when spinning, unrelated to ejecting.   So far they seems to work just fine, I've done about 20 ejects and all feel the same. We'll see how it holds up and I'll post here with any updates. VID_134060609_155824_339.mp4
    • Probably the best option will be to try to have a contact with Adam Goolevitch (Canada) who is the owner of one of the two Twiggy known units.   he was able to revive his own and the other one, has a lot of knowledge of Twiggy drives and Apple Lisas (1).   Has been there, done that...   probably a contact through Cult Of Mac i agree..
    • Finally I got Loctite 401 and glued the clip to the center cover. I left 24h before mounting and it looks very solid. It came in with a very satisfying click noise and stays in place properly.   I printed it with a 0.2mm nozzle and set layer height at 0.1mm to achieve better resolution.
