Jump to content
Sign in to follow this
Westinghouse
Another Mac SE/30 SCSI Problem
Recommended Posts
Hi there.
This is my first post on this board, but I've already used the information in threads here to narrow down my problem.
I recently picked up an SE/30 from a local shop, super cheap ($25).
It boots from floppy just fine.
It will boot from its hard disk into System 7.5.X and load all of the extensions, but immediately hangs at the desktop when loading the Finder, and the hard disk doesn't show up on the desktop.
It will throw various errors when it hangs, sometimes a bus error, sometimes error 10.
The hard drive also does not mount when booting from floppy.
It won't show up for Apple HD SC, but it will show up for Disk First Aid's first menu... but no luck after that.
Using a sketch from this forum, I checked the continuity between pins on the SCSI chip, and their corresponding pins on other chips and connectors.
Everything came out OK except for the DRQ pin (third from the cut corner on the chip - see attached sketch, I indicated the pin in red). I get nothing between that pin and the corresponding pins on the Glue Logic Chip UI8 or on UK11.
I started to run the traces backwards from the UI8 and UK11 pins.
They both have a connection to a particular point on the board (see board image - point indicated in red).
The image is not my logic board, but the layout is the same.
I show no continuity between this point and the DRQ pin.
I can't really follow the trace properly from this point back towards the SCSI chip, as it goes underneath the logic board power connector.
I'm wondering if putting in a bridge from the DRQ pin to this connection point will get me SCSI back.
I don't want to make a connection that will cause any further damage, though.
Any advice?
Edited by Westinghouse
Share this post
Link to post
Share on other sites
Nope, haven't changed the caps yet.
I know it's an issue because it doesn't bong on boot, and sound is really quiet from the speaker jack.
I'm not really confident in my ability to do so... I'm somewhat inexperienced, especialy with regards to desoldering on circuit boards, and afraid of lifting pads.
Does the DRQ line go through a capacitor?
The lead seems to go very close to the board power connector, adjacent to a cluster of caps.
Share this post
Link to post
I think before you beat it up any more you need to do something about those caps.  The are absolutely toasted.
bad caps can give you all kinds of freeky stuff man.
Bus errors,   dead scsi,  all that wild stuff.
Share this post
Link to post
Well, I ran a bridge over from the SCSI chip to the point I indicated on the board - success!
It boots right up now.
Thanks for the advice, and thanks to the forum - reading the threads on here about similar problems made it possible for me to do this repair myself.
Next step is replacing caps!
Share this post
Link to post
Hello Folks
recently recapped a Macintosh SE30 , even if the computer booted ( with no sound due to bad capacitors) it did not recognize neither  SCSI internal hard drive nor external scsi hd connected to the scsi port.
After recapp at start up  sounded strongly but the problem at SCSI still persist .
I tested continuity from SCSI controller 53c80 to Glue and SCSI 50 pin connector and found no continuity :
p6 scsi controller53c30   to p32 scsi connector
p33 scsi controller 53c80 to p38 scsi connector
I reconnected pins with wire .. and TA DAAA yep ! it's back to life again !
Share this post
Link to post
Excellent work.   Way to track down the problem.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
