Jump to content
Cloaked Alien
128MB Magneto-Optical Rewritable
Recommended Posts
Was just gifted this by my boss (the very guy who fixed my dad up with his SE/30 that I recently had techknight and uniserver repair the mobo for)
Anyways. I did a quick search and I couldn't find out much more than that this kind of media is recently common and standardised. The drive itself however... Does anyone know if it requires drivers for the mac (or pc for that matter)?
Share this post
Link to post
Share on other sites
Well, if you boot up a Mac with it connected and media inserted, it'll mount like any SCSI drive.
However, what you can do is open the case up and see what the make is of the drive.  Hopefully it's Fujitsu.  In any event, these drives are well supported even today.  Even if it's Cannon, Maxtor, or Pinnacle, you should be able to get drivers for it.
I think you'll like it.  You can still buy packs of newly manufactured media for it, and the higher capacity drives are backwards compatible with the smaller media.  So if you were to get a 2.3GB drive, you can still use the 128MB discs with it.
They're sort of like a hard platter version of a floppy disk.  They're very reliable.  I have two 2.3GB Fujitsu drives myself.  I use them for archiving my vintage software.
Edited by olePigeon
Share this post
Link to post
Probably the same technology NeXT used for a while (in the Cube) you probably need a driver.
It's exactly the same.  NeXT was the first company to use it in a commercial product, then the standard was made available to everyone.  Fujitsu and Pinnacle Micro were the big guys.
Share this post
Link to post
My money is on it's a fujitsu drive.
I forget what I did to make MO work under my quadra 950. I think I just used Pinnacle Micro's 3.5" MO driver and it was happy with hot mounting/unmounting.
Share this post
Link to post
Indeed, it's a Fujitsu. I only did a quick check yesterday as I was busy with some other tinkering. Drive probably needs some lubrication since it doesn't seem to close the door properly after ejecting media. I hope it's in working order. Otherwise I'll try to use the cabinet for a harddrive or something =)
Just hope I can find any drivers, at all =S
If anyone has a link I'd greatly appreciate it, even DOS/Win drivers since I have retro PC's with oldschool scsi controllers =)
Share this post
Link to post
Cheers, thanks!
I just tried it a bit with really weird results.
Using the Fujitsu exension or not does not make a difference. With Mac OS 7.5.3 properly booted it ejects the MO media as soon as I insert it, all three disks I have. No errors, no nothing.
The actual drive is a Fujitsu M2511A#N
Share this post
Link to post
Yes, they are 128MB. I tried it with my retro pc and it just plain worked. That means the disks are PC formatted. But I should at least be able to Mac format them before they get ejected =P
Well, first try I had the disc in when booting. As soon as I got to the desktop it ejected the disk...
Share this post
Link to post
The only other thing that comes to mind is that Fujitsu's drives had a tiny bank of dip switches for setting assorted things, including what it will identify to the host as and "Mac Mode" Which I never understood because Fijutsu's documentation is terrible.
With the driver loaded you should be able to insert a cartridge and if it's not mac formatted or you don't have FAT support installed, it will ask you to initialize it.
Share this post
Link to post
I tried loading the formatter first, same deal.
I did however start up my harddrive partitioning tool (can't remember what software it is right now) and while it was running it didn't eject any media. It did however show me that the drive was connected with ID 1 and was working.
I can confirm it has boatloads of dip switches, so that might just be something.
I've got FAT support installed, I haven't verified it though.
At least I've verified that the drive and media themselves are fine and working since it works under Win98 on my other PC =)
Share this post
Link to post
You really don't need to worry about defects. Magneto optical technology is possibly the most stable optical storage technology in existance. I've never seen a bad MO disk and I've seen a lot of really beat up cartridges.
Share this post
Link to post
They're essentially floppy disks but with platters instead of, well, floppy disks. :)
Here's a manual for the 1300/2300 model, dunno if it'll apply to yours.  It does have 4 dip switches for various options.
http://www.fujitsu.com/downloads/COMP/fcpa/mo/discontinued/dynamo-x300-scsi_user-manual.pdf
I didn't know that you can toggle it between MO mode and HDD mode.  The difference is that in HDD mode it'll show up as a SCSI HDD instead of removable media.  Pretty cool.
Share this post
Link to post
Switch SW1
        Key 1   OFF(*)   Reserved
Select SCSI ID
        Keys    2       3       4       SCSI ID
                OFF*    OFF*    OFF*    0
                OFF     OFF     ON      1
                OFF     ON      OFF     2
                OFF     ON      ON      3
                ON      OFF     OFF     4
                ON      OFF     ON      5
                ON      ON      OFF     6
                ON      ON      ON      7
Switch SW2
SCSI bus parity
       Key 1    ON(*)   Enabled
                OFF     Disabled
Synchronous Data Transfer Request Mode (SDTR)
       Key 2    OFF(*)  Disabled from TARG
                ON      Enabled from TARG
Device mode
       Key 3    OFF(*)  Direct access device (INQ = 00)
                ON      Optical memory device (INQ = 07)
Automatic spindle stop mode
       Key 4    OFF     Disabled
                ON(*)   Enabled
Command compatibility
       Key 5    OFF(*)  Sony MO compatible
                ON      ANSI compatible
       Key 6    OFF(*)  RESERVED
Macintosh Mode
       Key 7    OFF(*)  Mac mode off
                ON      Mac mode on
Send/Receive Diagnostic Command
       Key 8    OFF(*)  Rejected
                ON      Accepted
Terminal CNH 1   (For drives with serial above 30,000)
SCSI Terminating Power
     1-2        3-4        Function
     SHORT(*)   SHORT(*)   Power is supplied from the drive to both
                           the terminating resistor pack and the TERMPWR
                           pin on the SCSI bus. (Pin 26)
     OPEN       SHORT      The TERMPWR pin is not used. Power is supplied
                           to the drive terminating resistor only from
                           the drive.
     SHORT      OPEN       Power is not supplied to the terminating resistor
                           from the drive, only from the TERMPWR pin.
Terminal CNH1   (For drives with serial below 30,000)
     1 - 2      SHORT(*)   The TERMPWR pin is not used. Power is supplied
                           the drive.
     2 - 3      SHORT      Power is not supplied to the terminating resistor
                           from the drive, only from the TERMPWR pin. (Pin 26)
Terminal CNH1   (For drives with serial above 30,000)
     Pin        Signal
      1         CTRGIN (Cartridge in)
      2         -ID2 (bit value 4)
      3         +5VS
      4         -ID1 (bit value 2)
      5         ELED (LED control)
      6         -ID0 (bit value 1)
      7         EJSW (Eject switch)
      8         Ground
      9         DEVMD (Device mode)
      10        No connection
      11        MACMD (MAC Mode)
      12        No connection
Terminal CNH2   (For drives with serial below 30,000)
      Pin       Signal
       1        -ID2 (bit value 4)
       2        -ID1 (bit value 2)
       3        -ID0 (bit value 1)
       4        Ground
Share this post
Link to post
Okay, here's a possibility. Disks wiht different sector sizes depending on whether they are Mac or PC and the Mac mode switch controls the expected sector size. If you have a disk with a PC sector size and your drive is set to Mac mode, then it would likely reject the disk.
This is farfetched, but I have these vague memories of having a batch of MO disks with the wrong sector size back in the 90s -- only that was a Unix vs. PC situation, I think.
Share this post
Link to post
Well, I dunno. I'll experiment a bit and see what I can come up with =)
Don't think it's a repair job to be honest, seems like a factory fix.
At any rate. The drive came with 3 disks. They were in PC-format. I've extracted all the contents by connecting it to a PC machine. Despite the drive seemingly being in "mac mode".
Ah well, if nothing else I seem to be able to use it with a PC.
I'll keep you updated with any progress I make.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
