Jump to content
Sign in to follow this
ArmorAlley
Swapping PSUs among LC/Performas
Recommended Posts
Hi all
I need to get a new PSU for my Performa 475 (or, at least, I suspect that I do). I have an LCIII. Are the PSUs between the two interchangeable? The values written on them are a little different but, from what I have read, it seems that the LCIII PSU will work in the P475.
I would like to test the P475 PSU in the LCIII. Is this a bad idea? How about the LCIII PSU in the P475 until I can order one from uniserver?
Thanks for your help
aa
Share this post
Link to post
Share on other sites
For testing purposes it should be fine. But not for a swapping as a replacement. The LC 475 needs a little more current than the LC III, if you swap it the LC 475 will run hotter and burn out the PSU faster.
Share this post
Link to post
Uniserver can tell you how to fix your PSU or beef it up (bigger caps and other things replacement). He also has a few PSU he mentioned that he has for sale. I forget where he posted that.
Share this post
Link to post
I don't think it makes one bit of difference if you use the LCIII PSU in the 475. Both machines have the same case, same style internal peripherals, the only difference being the processor generation. From what I've gleaned on their specs, they both run at the same 50 watts maximum.
Edited by djhaloeight
Share this post
Link to post
Hi all,
Both power supplies are from Astec and have the following specs:
Mac | PSU Model Nr | Apple Part Nr | Output +5V -5V +12V
LCIII | AA16251 | 614-0003 | 3.75A 0.075A 0.78A
P475 | AA19140 | 614-0028 | 4.75A 0.075A 1.0A (and I wonder if the 475 in the machine name comes from the +5V ampage...)
Share this post
Link to post
It does. (Verified it with my LC475. Its safe to assume that the Q475 is the same too.)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
