Jump to content
Mac SE audio visualizer
  • Please log in to reply
4 replies to this topic
#1 narwhal2
narwhal2
  • 6502
  • LocationNorth Carolina
Posted 21 July 2014 - 04:25 PM
Hello
i have made a mac se audio visualizer. It is non destructive(the building process at least) and it looks awesome
i originally did it my mac classic ii, but the screen started to fade in and out and make clicking sounds(is this the flyback??)
anyways heres how i did it
sorry for terrible pics
Materials)
>18-20 gauge STRANDED wire
>some way to strip wire
>a female composite plug
>solder iron and solder
>torx 15 longgg screw drive
1)find a candidate
>needs to have a working screen/analog board
>needs mobo that can output signal. it doesnt matter if it is glitchy or garbled
>needs good psu
2)the build
>unplug the computer
>open the case and take off the back
>first DISCHARGE THE CRT.the voltage in the parts could injure you!
   >there are plenty of guides on how to this
>find the combo of yellow,green,red,blue wires and follow it to the analog board
>unplug the the combo of yellow,green,red,blue wires from the analog board and reroute it under the crt
>cut 4 good sized pieces of stranded wire
>solder some 1 wire to the ground and 1 wire to the signal of the composite plug(your wire should be longer then this and should be stranded, i replaced the wire after this pic)
>straighten the one end of all the wires and plug them into the plug you re routed under crt(positive and negative dont matter, i could have use all red wires if i had felt like it!)
>you need the composite  cable going to the yellow and the green wires!
>then, the wires coming from the blue and red, make a loop at the end not plugged in
>put the loop over the the bottom two pins on the analog board that had the bundle of wires connector
TESTING THE SYSTEM
>plug the annode cap back in and be sure the motherboard is plugged in too.  I would remove hdd/fdd too
>plug the system in
>if you get this line you did it right
>if you get a dot in the center of the screen, you have a loose connection
>plug sound source through the composite jack on the mac(so a red/white sound connector)
>start at low volume and increase
>get something like this(this was at low volume
FINISHING UP
reassemble the macintosh se
i stuck the composite cable out of the lock slot on the back.  i ducktaped the inside wire so it didnt pull through20140721_111953_zps7db63eca.jpg
I ownapple //c,   2  G5 servers, Macintosh Plus, Macintosh SE, Macintosh Classic II, powermac g3 desktop,  Powermac G5,  2010 macbook pro,   Powerbook 520c, Imac g4, Powermac G3 minitower, Macintosh Classic, powermac 7200/120, Powermacintosh G3 server,  powermac 6500/225, macintosh LC, Quadra 950
I sold:  apple //gs,  G4 cube, macintosh performa 6115 cd,   macintosh lciii, 2  Imac g3, Apple IIe, Boxed imac g3 slot loader, Dual processor quicksilver g4
#2 narwhal2
narwhal2
  • 6502
Posted 21 July 2014 - 09:54 PM
update
i posted an instructable on this
http://www.instructa...dio-Visualizer/
there it is
#3 olePigeon
olePigeon
  • 68LC040
Posted 29 July 2014 - 07:29 AM
Whoa.  Hard hack iTunes visualizer. :D
#4 narwhal2
narwhal2
  • 6502
Posted 29 July 2014 - 04:52 PM
just to let everyone know. this Macintosh SE is back in working condition! the only problem being some screen burn(not from the mod though)
#5 68kbits
68kbits
  • 6502
Posted 04 August 2014 - 04:47 AM
That's really cool, I have seen that vertical line many times from a cold solder joint, but it never dances :)
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
