Jump to content
Powerbook G3 Lombard 10.4 Wireless card
  • Please log in to reply
19 replies to this topic
#1 FlyingToaster
FlyingToaster
  • 6502
Posted 16 January 2012 - 01:23 AM
My Orinoco Gold (flashed silver) card doesn't work in 10.4 but it does work in OS 9. Are there any cheap cards that will work in 10.4? I don't want to buy the wrong one and it would be of help if someone already has this setup.
#2 stretch
stretch
  • 6502
Posted 16 January 2012 - 06:37 AM
I have a Motorola GN825G wireless adapter that worked for a while. When it works, it works great. The bad thing is that after a while, the card powers itself off and from then on, the system refuses to see it. I've seen this behavior with the system booted 10.3 and 10.4. I finally bought a USB wireless dongle that works only with 10.4 and I seem to be pretty happy with it on this Lombard.
I have a feeling my issue is a problem with the motherboard. This machine also refuses to recognize the battery. I've changed everything except the motherboard troubleshooting the battery issue. I refuse to buy a motherboard for a 13 year old machine hoping it will fix the problem. For what I use this machine for, I'll live with it's problems.
None of us is as smart as all of us.
#3 J English Smith
J English Smith
  • 6502
  • LocationDes Moines, Iowa
Posted 16 January 2012 - 02:10 PM
On my Lombard that is running 10.4, the Motorola WN825Gv2 card works well. These are available for around $8-10 on the 'bay. My memory is that Tiger recognizes it as an Airport card with no additional drivers.
(With my other Lombard that is running 10.3, I can get the Orinoco card to work at the office, but not at home. Weird. It seems to be incompatible with the specific DSL modem, because I've changed all other parameters. Oh well.)
Macs: 1400c (8.6), PB G3 Lombard 400 (10.4.11), many Pismo G3s 400/500 (10.4.11), iBooks 500/800/1.33ghz (10.4.11 and 10.5.8)
PCs: Dell Dimension (Win 98se), IBM Tower (Ubuntu 14.04 LTE), HP Tower (Win 10), Lenovo T60 (Ubuntu 14.04 LTE)
#4 BGoins12
BGoins12
  • 6502
  • LocationAmherst, Ohio
Posted 16 January 2012 - 02:19 PM
I can't remember the model I had, but it was a Belkin card. It worked with the 10.4 Airport drivers because it had the same chipset in it as the airport cards do.
EDIT - Here you go. http://www.ee.columb... ... rport.html
2.5 i5 Mac Mini (Late '12), Dual 1.25 MDD, 1.42 eMac, 5500/275, 7600/120, 8500/120, 7100/80AV, 6100/66, LCII (w/LCIII Board), PB 520, a few PCs, and a 8GB Nook Tablet. More in my link --------->
#5 MacJunky
MacJunky
  • 68000
  • LocationBC, Canada
Posted 16 January 2012 - 11:44 PM
I used to use a Linksys WPC54G v3 with the built-in airport drivers. (but you might have to run software update a couple times to get the latest, I had to do that in both 10.3 and 10.4 on my PDQ)
LC 630, P580CD, LC 575, Mac Plus X2, PowerBook 160, PowerBook 150 X2, PowerBook 145
#6 FlyingToaster
FlyingToaster
  • 6502
Posted 17 January 2012 - 12:43 AM
The Beta 6 Tiger driver from http://sourceforge.n... ... essdriver/
works great so far! Thanks Strimkind for the help!
Thanks to all for the card suggestions too! A good reference to future owners
#7 coius
coius
  • 68030
  • LocationOmaha, NE USA
Posted 17 January 2012 - 02:34 AM
I know for a fact the Belkin F5D7011 ver.1000 does work. I use one in my Pismo for WPA/WPA2 access
Preliminary operational tests were inconclusive (the damn thing blew up).
#8 bibilit
bibilit
  • 68000
  • LocationParis area -FRANCE-
Posted 23 January 2012 - 08:35 PM
The Airport card is using a BCM 43 xx Chipset and all the following cards are known to work with the Airport soft :
Asus WL-103B
Asus WL-100G (classic)
Belkin F5D7010 (first version only)
Belkin F5D7011
Belkin F5D7011FR
Bewan Wifi PCMCIA 54
Linksys WPC54G V1
Linksys WPC54GS
Microsoft MN-720
Motorola WN825G PC Card
Sagem WPCB-128G
Sony Ericsson GC79
Tecom WL5021
Trendnet TEW-401PC
Trendnet TEW-401PCPlus
And the usb D-link DWL-g122 is working too
Macintosh Classic and II ,CC, SE, SE/30,IIsi 25mhz(RasterOps video),Q 700,LC, LC III,LC475, PBook Wallstreet/Bronze/5300cs/1400c/100/Tibook Imac G3 slot-in, Bondi and G4 / PMac G4 sawtooth, QS, MDD, Yikes!, Cube, Imac Core 2 Duo, Ibook G3 (white/clam) G4 + Newton 120, eMate 300,Quicktake 150,  PowerCD
#9 Sludgedragon
Sludgedragon
  • 6502
  • LocationOregon
Posted 19 July 2012 - 06:36 AM
I thought a Lombard couldn't go past 10.3??
#10 CC_333
CC_333
  • 68LC040
Posted 19 July 2012 - 07:16 AM
Hi,
The Lombard isn't supported per se, but 10.4 will run. One can bypass the checks in the installer by using X Post Facto or installing onto a supported machine's drive and transplanting that drive into the Lombard.
c
Main Macs: Early '09 Mac Pro, Mid '12 MacBook Pro 13" --- Secondary Macs: Early '08 Mac Pro, Mid '12 MacBook Pro 15"
Playthings: Mac SE/30, 3.0 GHz Mavericks-based HackServe, Many others... --- Desired: Lisa, Kanga PowerBook G3, Apple IIc, Apple II, Spare parts, etc.
#11 J English Smith
J English Smith
  • 6502
Posted 20 July 2012 - 02:22 AM
And man, the Lombards are so much better under 10.4 for normal tasks. Max out the RAM and transplant a drive from a Pismo - you'll like it!
#12 Bunsen
Bunsen
    Admin-Witchfinder-General
  • Administrators
  • LocationMelbourne, Australia
Posted 20 July 2012 - 11:09 PM
Hey bibilit. Thanks for that list - where did you find it?
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
#13 J English Smith
J English Smith
  • 6502
Posted 20 July 2012 - 11:16 PM
Hey, at my new workplace I've been unable to hook to a WPA2 guest network with the original Airport card. I ordered an Airport Extreme PCMCIA card today. That should solve the problem, right?
The guest network at my other office location is an open network with a simple access agreement and the original Airport card handles that just fine, of course.
#14 quinterro
quinterro
  • 68000
  • LocationRaleigh, North Carolina USA
Posted 25 February 2013 - 02:51 PM
I have a TrendNet-based card in mine, but I haven't used it in a while. The chipset on it is a Realtek RTL8185. While 10.4 doesn't support it out of the box Realtek has drivers for it on its web site.
Once those are installed it works quite well.
Snowball: iBook G4 1.33ghz Blackbird: PowerBook G3 333mhz Smudge: HP Touchsmart 15
#15 gsteemso
gsteemso
  • 6502
  • Locationnorth of Seattle, USA
Posted 24 June 2013 - 06:56 AM
Apple’s original AirPort card appears to be physically incapable of WPA/WPA2 encryption. The software doesn’t tell you, of course — it just silently fails to work.
Where did you find an AirPort Extreme PC Card? Apple AE cards are a different, larger size, and I seem to recall that even the PC Card shaped original AirPort cards wouldn’t work in a normal PC Card bay, only in a dedicated slot.
My 800MHz DVI TiBook seems to have a bad AirPort card slot — every card I’ve tried in it died within a month, so I’m very very interested in this thread.
The world’s only gsteemso
Agitator-in-Chief for the Seattle Retro-Computing Society
http://www.seattleretrocomputing.com/
#16 TheMacGuy
TheMacGuy
  • 68000
  • LocationSouthern California
Posted 24 June 2013 - 06:22 PM
WPA will work on the original AirPort Card. You need to be running 10.3.9 Panther and the AirPort 3.3.1 software update (AirPort 3.3.1 is not a combo updater, 3.3 is. You need to upgrade to AirPort 3.3 then install 3.3.1).
AirPort Card: When You Can Join a WPA Network
Plat IIe, 512kE, Plus, SE, P200, Q: 605 650, C610, PB: 165 210 5300cs 5300c G3PDQ TiG4 2x Al 12" 2x Al 15", PM: 6500 Cube Sawtooth, eMate, iBooks: 1 Tang 1 BB 1 Indg Clams 12" Ice G3 14" G4, 2 iMac G4, 2x PMG5, MB1,1
#17 J English Smith
J English Smith
  • 6502
Posted 26 June 2013 - 05:24 AM
When you are in 10.4.11, the Motorola wn825g pc cards work fine with the wpa2 encryption. Am using those now for both home and work networks.
#18 quinterro
quinterro
  • 68000
Posted 08 September 2013 - 02:01 AM
The model is TEW-421PC. Hardware revision is C1.0R. In the original post it worked on my home and work wireless networks. At my new job it connects but does not get an IP address. The work wireless is using WPA2-TKIP. Didn't know if it was related to the card or the OS.
#19 bibilit
bibilit
  • 68000
Posted 03 May 2014 - 01:44 PM
For further information, i am posting successfully with a Lombard 10.3.9 with a third party card ...this one is using natively the Airport software. I was even able to connect to my WPA2 protected network. To achieve this result, you should upgrade to Airport 4.2 under Panther (10.3 and above) I will advise which cards are working that way.
#20 bibilit
bibilit
  • 68000
Posted 03 May 2014 - 02:42 PM
So far i have been able to use two cards flawlessly:
Sagem WPCB-128G
Sony Ericsson GC79
Those are detected by the Airport panel without any issue.
I was able to pick up my network, to setup the WPA2 password and to connect the web easily.
I have tested another set of PC cards, none of them were detected as Airport cards, including The Orinoco Silver.
Probably a trick can make it work...
As you can see, the Airport icon is present side by side with the Cisco one  :beige:
Edited by bibilit, 03 May 2014 - 02:44 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
