Jump to content
G4 processor swaps
  • Please log in to reply
24 replies to this topic
#21 Byrd
Byrd
  • 68020
  • LocationMelbourne, Australia
Posted 08 June 2016 - 10:08 AM
The CPUs do look the same, but the Xserve dual CPU seems to have more components on it - I'd be a bit wary.  You could probably pick up a dead dual MDD for next to nothing anyhow to transplant the CPUs.  Keep in mind depending on the bus speed/model you may need to physically switch resistors on the card to get the right multiplier at the right bus speed.
:: Current project Mac: PB1400 resto
#22 waynestewart
waynestewart
  • 6502
  • LocationVancouver BC
Posted 09 June 2016 - 03:19 PM
I had too many G4 xserves so I swapped a dual 1.33 over to a MDD. Works fine, I've had zero problems with it
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
#23 brirec
brirec
  • 6502
Posted 12 June 2016 - 05:47 AM
Best IMO is a dual 1.42 from a fw800 model in a fw400 model. You have to either swap the heatsink too or modify the CPU (relocate an inductor… not terribly difficult but it requires soldering to the CPU board) because otherwise it won't fit, but Mac OS 9 at 1.42 GHz and an SSD is pretty insane.
Edited by brirec, 12 June 2016 - 05:47 AM.
#24 Knez
Knez
  • 6502
  • LocationSweden
Posted 10 November 2016 - 12:44 PM
I currently have a Dual 1.25ghz board overclocked to 1.5ghz. No problems with it since the overclock was made around 5 years ago.
#25 AlpineRaven
AlpineRaven
  • 6502
  • LocationMelbourne Australia
Posted 09 August 2017 - 10:01 AM
You dont need to modify anything on G4 MDD CPU - doesn't matter if its FW400/FW800, as long the system bus is 167mhz. (If its not 167mhz then you do need to modify it)
Cheers
AP
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
