Canby Fat Mac 6502 Nov 10, 2015 #66 Here is a good example of my fifth attempt. The CRT is missing and you can see where the battery popped in the inside Last edited by a moderator: Nov 10, 2015
Canby Fat Mac 6502 Nov 10, 2015 #67 Here was my third attempt, I forgot to stir before applying and it burned the lower left of the front
uniserver 68LC040 Nov 10, 2015 #68 oh it looks like they are back in stock of the liquid stuff. http://www.amazon.com/Stabilized-Crystal-Liquid-Peroxide-HC-50409/dp/B00TP1IZDE/ref=pd_sbs_194_5?ie=UTF8&refRID=1WFY548HJGN6YJGQCPKQ
techknight 68040 Nov 11, 2015 #69 It looks so white, its almost as if you bleached the "beige" out of it.
Paralel 68020 Nov 11, 2015 #70 techknight said: It looks so white, its almost as if you bleached the "beige" out of it. Click to expand... Not a problem, IMO...
2dfx 6502 Nov 15, 2015 #71 techknight said: It looks so white, its almost as if you bleached the "beige" out of it. Click to expand... Bah, trying to buy 40 volume developer of this quantity in Canada is impossible...
rsolberg 68000 Nov 15, 2015 #72 It does rather seem that way. This is the most economical option I've seen online thus far: http://www.amazon.ca/dp/B00FKVYCHQ/ Edit: it looks like beauty supply wholesalers are a better option. If you're in an urban centre, a local wholesaler would be ideal. http://www.discountbeautycenter.com/43152-advantage-40-volume-creme-developer-16-oz Last edited by a moderator: Nov 15, 2015
