Wow.
Moving day will be quite the ordeal though. Imagine having to takedown, transport and set-up all those machines. Surely some would meet with an undesirable fate along the way.
If they don't work - interlink them all into the world's biggest MacQuarium.
That would be hella cool.
Saw that one a wee while ago - it is one really impressive collection of compacts! You would be flattened if they decided to topple over on you though.
I don't think those are all plugged in though. No ordinary home or even most businesses would have enough power to run them all at the same time.
My storage unit is basically entirely full of Macs now, mostly AIO G3s, 5xxx and 5xx Macs that I'm working on selling. Some of the schools are auctioning off even MORE Macs at like $1/pallet now so I may have to get another storage unit!
I kick myself every day for not knowing about the auctions earlier - several years ago one of the school districts here phased out Apple IIGS computers - and I just know they auctioned them off for pennies on the dollar!
Is there some sort of story to go along with the picture?
I wish it was available in high resolution. It would make a cool background. :)
What I want to know is, when is the sheer weight of all the upper Macs going to crack the plastics of the lower Macs and bring the entire mountain of machines crashing to the floor?
Seriously, it would be more prudent to put each row of Macs on its own shelf. I suppose a few rows of Macs stacked atop each other wouldn't hurt for long term storage. But count how many rows there are in that photo! I would be very, very afraid to take a step in that room, more less sit at the desk shown in that photo. Scary!
Eight rows of Macs, JDW. Certainly, the vertical load is way past the expectations of the original Mac designers. There are a few mitigations, however.
The Mac case design is sufficiently squat that we don't have to consider Euler's column theory. The cases are unlikely to collapse en masse in a cascade (which might happen if Euler was valid). If one case fails, the most likely consequence is that it will exert a lateral load on the Macs surrounding it and onto the walls beyond. Given the constrained space, it is unlikely that a Mac might topple, even from the row above a Mac that has collapsed.
The most dodgy row is #7, where the number of Macs in the row is reduced from eleven to ten, leaving a gap on one side and the opportunity for Macs to fly.
But this is all presumptive. Before stacking up the Macs, what else did the owner do? It looks like a damned posh cellar to me and I find it difficult to believe that "staying up" was not part of the owner's calculations.
Charlie, thank you for the detailed analysis. I think it would be nice if the owner of that cellar would put a video camera down there and leave it recording 24/7. So when those Macs do come down, we can see how well the theory matches the experimental! :beige:
And if they do work, beowulf 'em!
Add all those together and you might get something with the power of an early G3 iMac :p
That pic. was first linked to in these forums some time back, perhaps even before The Fall. That the Macs are still standing now, several months later, shows that one can be too analytical, and thus be undone in calculations from such parameters as gross weight, vectorial forces, intrinsic rigidity and the like. Look closely, and you will see that the backs of the Macs are lightly blue-tacked to the walls ... ;)
de
Everything old is new again, eh equill?
The laws of physics aside ... I have seen too many of these old compacts in my time to know that the vent grilles on top were never designed to support the force exerted by the focused weight of the mac vis-a-vis its feet. It saddens me to think of all the cracks which are fracturing in the brittle plastic as we write.
Nevertheless, a sight to behold.
P.S. anyone who does this at home, should either adhere to JDW's shelf suggestion, or at a bare minimum place a sheet of Plexiglas or other solid material between each layer to evenly distribute the weight. Anything over three for four layers should be well adhered to the wall as well, even velcro should do it.
