Accelerator Failure Total Systems Macintosh Plus
That RAM expansion board is removable, and looks like it has already come partway loose. I would fully seat that connector and try again. That board will work without the RAM expansion, it will just use the RAM on the Plus logic board, it is accessed more slowly than the RAM on the expansion. I don't know if there is a jumper or anything that needs to be changed if you remove the RAM board. I have the same accelerator, which has since failed, but used to work without the RAM expansion.
