I am in need of opinions!
I'm setting up a Performa system for use at my grandmother's house. It will be used mainly for Microsoft Word, and Quicken, however it will also have a modem for some internet access, possibly email. The only part I can't decide on, is which monitor to pair with the machine. There are two options: an Apple Color Plus 14" display, or an Apple Multiple Scan 15" display. Here are the pro's and con's that I've come up with.
Color Plus 14":
Pro's - Takes up less space, 640x480 is fine, more reliable than MS 15".
Con's - Smaller screen, no built-in speakers.
M.S. 15":
Pro's - Bigger screen, more resolutions, built-in speakers
Con's - Takes up more space, known to have product defects (therefore less reliable than the Color Plus).
Both are in good working condition. While the Multiple Scan 15" display is fine now, I worry that it may develop problems later. Does anyone have any advice as to which monitor I should pair up with the Performa? I'm torn between the two!
Thanks in advance!
Color Plus 14":
M.S. 15":
Thanks in advance!
