This is an odd issue:
On my SE/30, recently acquired and recapped, everything works fine up until you try to use peripherals. If there is a mouse plugged in, the machine will boot but the mouse is slow and jitters, no matter the surface, even if manipulating the rollers manually. If there is a keyboard plugged in (Apple Keyboard II in this case, works fine with every other ADB Mac I have) then it hangs shortly after the "Welcome to Macintosh" screen. Unplugging the ADB cable will immediately allow the boot to continue. I'm booting from a 20SC in this case as the internal HD is dead and no HD20 support.
I have not observed this on any other machine, and I know both peripherals are good. Happens with both of the ADB Mice I have, too.
