So I was considering using the 120 GB hard drive from my Acer in the G3 once I've got my new PC sorted and the files off it, but judging by the prices of similar new drives and what used ones sell for, it would hardly cost anything to change it for a brand new one, as opposed to one that's spent the last 3 years at 50-60 C inside that laptop. However, 120 GB and 160 GB ones seem about the same price, but I'm aware that the Beige G3 has problems with drives above about 128 GB, so what would happen if I got the 160 GB one? Would it work but only the first 128 GB would be visible in the formatter, or would it throw a hissy fit and refuse to work with it at all? If the former is the case, are there any tricks for getting the extra space useable, apart from getting a separate IDE card?
And will any brand new IDE drive work, or are there issues with using a drive that's 9 years newer than the machine?
Thanks!
Thanks!
