Umax c500 crashing out
ok, here's the problem, ive got the hard drive, but it's still locking up, and it was doing this before the crash, I have the HD partitioned into 2, and ran diskwarrior by booting the other partition, and it found no errors. and when i booted it from the other partition, no problems. ive trieed cleaning out the extentions folder, and control panels, deleting the preferences, all to no avail. Any suggestions?
check the recent servers?
have you had to connect to another machine during the time it had it's last OS install?
The second thing I can think of, is bad harddrive sectors. which means, it is trying to read something that is garbled. Then it would be time for a new drive :p
yea, i just reinstalled the os, and ur right, i think that it might have had something to do with my old appletalk servers. but i reinstalled the os, and it runs great! thanks!
