hey genie, for now its mega simplistic.
basically this IIsi video card, had to be modified in order for it to fit in the case.
So i loped a controversial hunk off the card.
It just so happen to not kill anything.
The only other thing I did, is the video card didn't come with any Cable or db-15 video connector.
so i had to solder that IDC cable to the card header and then to a de-soldered db-15 from a killed LC that i had laying around
from GUAM
, the bare main board sat in a shed, the guys home was right on the beach too
needless to say this LC board had rot worse then anything i have ever seen
Anyways, so after i loped the hunk off the video card, and made that video cable. I popped the Video card onto the Maccon network card, because there was no physical way the video card was going to fit directly onto the PDS of the SE/30.
Had to remove the HD/floppy cage as well.
then all i had to do after that was turn the computer on and see what happens. and with out installing any software just running 7.5.5, oh and with dougg3's IIsi Rom simm installed.
The video card just works. The dual screen feature just works. The internal CRT automatically became Display#2. and the out put to my LCD screen became Display #1
as to the Grey scale… i have no idea of those in's and out's, you are saying we will need to add more transistors in order to display more then one bit, would it be 4bit's for 256 grey scale?? Maybe that is something techknight over looked?
if you would like to work on the greyscale project i could send you one of these iisi pivot cards with that kbd and mouse you also need.
I would think once we come up with a grey scale solution i would say it should be worth at least 500 bucks.
I mean that is half the price of the Micron Xceed solution that is being sold currently.
from GUAM
