Trackpad double click with System 9.2.2 ?
If I boot my Clamshell iBook in OSX and then start the Classic System 9.2.2 I retain the OSX setting to double click on the trackpad.
If I boot into System 9.2.2 I can't use double click on the trackpad because I can't find a control panel to let me set this function and I find the computer harder to use without it.
Is there a control panel that will work with 9.2.2 which will give me this function or am I at odds with the dual nature of these machines. [?]
Hi Elfen,
I checked, when I boot into System 9.2.2 the mouse control panel (version 8.1.1) only allows me to alter the double click speed of the mouse, it doesn't allow me to enable double click on the trackpad under System 9.2.2, and I can't find anything related to the trackpad?
Ooops!,   [:I] ]'>  my System 9.2.2 is from a universal install CD downloaded from Macintosh Garden as I didn't get any disks with the Clamshell, the OSX is a retail version too, but that said, could my problem be fixed with a machine specific Clamshell iBook control panel??
BTW: when I copied a Mac mini G4 system to a Cube G4, I didn't get any sound. I would install 9.0/.1 and do the updates.
I also put System 9.2.2 on a partition which I suppose might not help integration with the functions of OS 10.4, but the lack of double clicking the trackpad in System 9.2.2 is just a minor irritation of an otherwise fully functioning great machine.
