if i can figure it out on my 32bit pi2, you can tooWell, that would explain it... In reading the preceeding pages of this topic I get the impression that the more common tun/tap utilities can also do the trick, but if the recipe is there I must have missed it. Can this work, or do I need to pickup a 64-bit RPi?
That's terrific news. I assume this update would be to a beta or testing release, correct? Where do they publish those?So I just brought this up in the Void IRC channel...
<abby> if you know what the kconfig option is called i can add it next update, which I'll probably do today
You wouldn't get that kind of service from Debian. =D
This should work but I don't know for sure... I've only ever used wired networks on Pis (and linux in general). I don't know where you'd be setting the SSID or password for example.I'll give that long set of directions a shot. Couple of questions:
- Can 'wlan0' be substituted for 'eth0' in order to use Wifi?
Huh I didn't make that clear did I. If you follow my steps, you're assigning a static IP address to your Pi.
- With dhcpcd disabled, how does the RPi get assigned an IP address?
iface br0 inet static
address 10.40.0.216
gateway 10.40.0.1
dns-domain local.default.tel
dns-nameservers 10.40.0.1 1.1.1.1 8.8.8.8
bridge_ports eth0 tap2
With the TashTalk 2 hat, you actually need to use LT or PhoneNet dongles and cables.Before I let the smoke out of something, is it safe to directly connect the tasktalk hat to an Apple //gs serial port - or do I need the localtalk transformers + phone wire in between?
root@tashtalk:~/tashrouter# ./taprouter.py
router away!
2024-03-06 16:21:37,608 INFO: starting LtoudpPort...
2024-03-06 16:21:37,616 INFO: LToUDP assigned network number 1
2024-03-06 16:21:37,621 DEBUG: router adding: RoutingTableEntry(extended_network=False, network_min=1, network_max=1, distance=0, port=LToUDP, next_network=0, next_node=0)
2024-03-06 16:21:37,634 DEBUG: router adding network range 1-1 to zone LToUDP Network (now default zone for this range)
2024-03-06 16:21:37,641 INFO: starting TashTalkPort...
2024-03-06 16:21:37,647 INFO: ttyAMA0 assigned network number 2
2024-03-06 16:21:37,650 DEBUG: router adding: RoutingTableEntry(extended_network=False, network_min=2, network_max=2, distance=0, port=ttyAMA0, next_network=0, next_node=0)
2024-03-06 16:21:37,654 DEBUG: router adding network range 2-2 to zone TashTalk Network (now default zone for this range)
2024-03-06 16:21:37,663 INFO: starting TapPort...
2024-03-06 16:21:37,675 INFO: tap2 assigned network number range 3-5
2024-03-06 16:21:37,680 DEBUG: router adding: RoutingTableEntry(extended_network=True, network_min=3, network_max=5, distance=0, port=tap2, next_network=0, next_node=0)
2024-03-06 16:21:37,688 DEBUG: router adding network range 3-5 to zone EtherTalk Network (now default zone for this range)
2024-03-06 16:21:37,708 INFO: all ports started!
2024-03-06 16:21:37,712 INFO: starting EchoService...
2024-03-06 16:21:37,717 INFO: starting NameInformationService...
2024-03-06 16:21:37,722 INFO: starting RoutingTableAgingService...
2024-03-06 16:21:37,727 INFO: starting RtmpRespondingService...
2024-03-06 16:21:37,732 INFO: starting RtmpSendingService...
2024-03-06 16:21:37,737 INFO: starting ZipRespondingService...
2024-03-06 16:21:37,743 INFO: starting ZipSendingService...
2024-03-06 16:21:37,749 INFO: all services started!
2024-03-06 16:21:38,623 DEBUG: router adding: RoutingTableEntry(extended_network=False, network_min=256, network_max=256, distance=1, port=tap2, next_network=1, next_node=28)
2024-03-06 16:21:39,902 INFO: LToUDP claiming node address 254
2024-03-06 16:21:39,907 INFO: tap2 claiming address 5.229
2024-03-06 16:21:39,916 INFO: ttyAMA0 claiming node address 254
2024-03-06 16:21:47,764 DEBUG: router adding network range 256-256 to zone LocalTalk2ZoneA (now default zone for this range)
$ ./nbplkup
dockstar:ProDOS16 Image 1.163:3
dockstar:Apple //e Boot 1.163:3
dockstar:AFPServer 1.163:129
dockstar:Apple //gs 1.163:3
dockstar:netatalk 1.163:4
dockstar:Workstation 1.163:4
HP LaserJet 2200:SNMP Agent 1.4:8
HP LaserJet 2200:LaserWriter 1.4:158
HP LaserJet 2200:LaserJet 2200 1.4:157
HP LaserJet 2200:HP Zoner Responder 1.4:156
quadra:A/UX 185.182:128
<Unnamed>:Macintosh Quadra 650 185.182:252
Gator_Hirsch:GatorBox 256.133:128
Gator_Hirsch:GatorBox CS 256.133:128
Gator_Hirsch:SNMP Agent 256.133:8
