System 7.5 language change
replacing System and Finder with the appropriate ones will change language, done a couple of times, don't remember if ever tried with 7,5, but sure worked with 7,1
I was wondering if I could change the language because I just got a duo with a French operating system and I don't have a dock
Or floppy drive
Without the dock or floppy drive, or removing the hard drive, the only way to transfer something would be with LocalTalk via the serial port with another Mac.
If you have a duo and no sort of dock you're doing it wrong. You need at least a floppy dock!
