Performa 475 System Installer fault ...
franklyn
Macintosh Performa 475 with full 040 CPU and 128MB Ram and Mainboard set to 33Mhz CPU Clock and BlueSCSI
I can not install a system 8, 7.6 or 7.5 from CD ROM or Floppy Image files, see the picture ...
Yes it's the overclock causing trouble. You can use an emulator like Basilisk to install onto the disk image you're using. You could also revert back to stock 25MHz speed to do the install, then try the overclock again. Easiest thing would be to install from a modern computer, then reinsert the SD card back into the BlueSCSI. You'll be amazed at how fast an OS installs in Basilisk!
Put the BlueSCSI Device on my Quadra700 also Overclock to 32Mhz and install the System from CD Rom and use it than with the Performa 475.
