... my system is a Performa 475 with 128MB RAM and XC68040 CPU and BlueSCSI Desktop Version buying 2024 with two HD Images on it. HD0 with System 7.1 and then HD1 with System 7.6.1 The problem is when I use/mount the SD card with my modern macOS Computer (M4 MacMini) to add a CD image for example, and then eject it properly, the 68k Computer no longer boots.
A Sad Mac appears with "0000000F / 00000001"
or "0000000F / 00000002"
or "0000000F / 00000003" ... .
After the 10th reset via the keyboard, the Computer boots every now and then. The first aid program finds no problem.
What can I do about it?
